I am using Hypriot as OS . I have done modifications to some file and script,and i have add new service on boot . I would like to know if i have a newer version of Hypriot how can i update my customised OS to newer version without losing modification ? Or should i create a script that modify the new operating system ?
Thank you in advance
zamankar
Debian is able to upgrade to a new version but it is not an easy task for the upgrade procedure. It has to decide how to upgrade options you have modified and/or set. If it doesn't know it will ask you what to do. Usually it will present the old configuration as default but it may not be always the best decision. This also implies that you will not get exactly the same installation than from a new installation of the new version. But the result is mostly very good. But you may miss new features from the new version because it tries to use the old configuration as already said.
You should clone your current installation on a spare SD Card and do the upgrade. If it doesn't show the expected result you can try again. When you have changed the settings in /etc/apt/ to the new repositories then the commands to upgrade are:
rpi ~$ sudo apt update
rpi ~$ sudo apt full-upgrade
Ingo
  • 42,961
  • 207
A rather straightforward approach would be:
  • flash your original (old, no modifications) image to a spare SD card
  • diff between the no-modification image and your current image
  • flash the new image (again, no modifications) to the spare SD card
  • apply the changes you've done to the old image to the new image with patch
If you don't have the above-mentioned tools, you can install them (on Debian) with
apt-get install diffutils patch
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
