I need to be able to play up to 8 mp3 files at the same time. Is this possible with the raspberry pi 3b+? They need to be started in python code.
I believe this is a simple issue of running the mpg123 command multiple times.
sudo apt-get install mpg123
man mpg123
If you want it in python
import subprocess
subprocess.run(['mpg123','<your options>'])
- 21
- 2
Based on my answer here:
The test is done on a Pi Zero with a recent Raspbian, Python 3.6, vlc (along with approx. 150 other packages), and it's Python-bindings. It's using a USB soundcard and alsa.
Playing from Python worked straight forward:
import vlc
instance = vlc.Instance('--aout=alsa')
p = instance.media_player_new()
m = instance.media_new('something.mp3')
p.set_media(m)
p.play()
p.pause()
vlc.libvlc_audio_set_volume(p, volume) # volume 0..100
I was able to run four independent mp3's from a single Python process with a CPU load of about 87%. Starting a fifth player resulted in this error:
alsa audio output error: cannot estimate delay: Broken pipe
Given the more powerful CPU of the Pi 3B+ and its four cores I dare say it'll work. Use multiprocessing though to allow for the distribution of the load to more than one core.
Further reading:
- 15,958
- 17
- 65
- 125
I have an idea, why not you use Python to play sound. Here is some code: Before the code, you will need this library installed in your project.
# Import the library, and have it installed in your project
import simpleaudio
# Variables
sound_1 = './sounds/correct.wav'
sound_2 = './sounds/correct.wav'
# Use this function in your code to play sound
def playsound(directory):
play = simpleaudio.WaveObject.from_wave_file(directory)
play.play()
# Play the sound and wait for the sound to stop playing before continuing with the code
def playsound_wait(directory):
play.play().wait_done()
# Run the code below to play the sound (I used the sound_1 and sound_2 variable)
playsound(sound_1)
playsound_wait(sound_2)
Hope this makes it simple
- 368
- 2
- 3
- 15
