I tried to force audio to audio jack with amixer cset numid=3 1 or using the raspi-config which works for other applications like audacity, vlc and other multimedia software except for the alarm clock alarm-clock-applet https://github.com/joh/alarm-clock , Which I am using for a project. I tried removing pulseaudio to avoid conflict but yet no success.
The alarm clock plays audio only via HDMI. I am using the new Raspian Buster. The Alarm Clock do not work properly on previous Raspbian.
I need help to get audio out via USB Audio PnP Sound Device or default audio jack. If it will be possible to modify the settings of the App which I am still trying to find out how.
ellooku
  • 156
wrote a quick script for this
https://github.com/Skarlett/pi-alarm
If someone could link the details to getting audio to play through the raspberry pi audio jack, you need omxplayer to use it via bash. (probably some header files somewhere included for programmatic use). You'll want to reboot after you install it.
#!/usr/bin/env bash
for i in $(seq 60)
do
    # echo $i
    omxplayer default.mp3 > /dev/null
done
As for a general solution for all applications? I think they all link back to having this application and its libraries, but I'd have to check up with you on that.
If you want to actually use the script solution - then you would want to hook this up to cronjobs
Christian
  • 111
I decided to play the audio out for the mean time using VLC Media Player by adding this custom command
vlc --vout none /path/to/alarm.mp3
on the Alert Start Application Box. Which works very well while I keep trying the default to see what went wrong.
ellooku
  • 156
