The way I setup the RPI is through sharing my laptop's connection via ethernet. I enabled SSH. Now I am trying to SSH from it without being hardwired to it the way I set it up and the connection keeps timing out. While sharing my PC's internet with the RPI I can SSH fine.
So I tried everything in this post: SSH - connection timeout when connecting
  • I can ping it from my PC when I'm on the same network (hotel network), but it gives me "Destination net unreachable", then says that no packets were loss. Now that I'm on a different public network I can't ping it. I just get that the request gets timed out.
  • I set up SSH using raspi-config.
  • I can SSH from the RPI itself.
  • I can SSH from the RPI itself using the actual address and port.
  • I added ports: 80 and 55555.
Any ideas as to what could be the issue? I've read a lot of other posts, but I think I've done most of the tips given. The only thing I'm thinking is the way the hotel network is set up. AP isolation?
First of all check firewalls. Routers have an option to isolate clients. Check if you have installed ufw and disabled ports. Check if both pc and raspberry pi are in same network. aka network part of ip same. Check if windows is not blocking connections. Now a days windows is preloaded with a restrictive firewall, after smbv1 apocalypse. Check if you can ping each other, if dont work one way try other way. Windows blocks ping by default. Disable firewall or add a rule for ICMP packets. Boot linux [live or installed] in pc and check if linux allows you to connect. If this worked. Culprit is windows firewall. Check file transfer or remote access in general, like host a http server in phone and check.
Hope this helped
