My Raspberry Pi, running Raspbmc, hangs randomly while navigating in the menu/settings.
Any hints what I could check to find out what's happening when it hangs?
Is it crashing or just hanging?
You can try the top command it will show the usage of your resources
CPU: 34.3% usr 10.8% sys 54.0% nic 0.0% idle 0.0% io 0.1% irq 0.5% sirq
Load average: 5.66 4.22 3.35 4/110 24166
I am using OpenELEC which is oriented on XBMC for small devices, it is not stable yet, but it worth the try (running OpenELEC-RPi.arm-devel-20120914034643-r11925).
I do have small glitches in the navigation menu when the RPi is indexing media files or doing other operations.
The RPi is built to do hardware decoding of specific formats. But since august 24th, if you buy some licenses you can decode MPEG-2 and VC-1 : http://www.raspberrypi.org/archives/1839
Hope this helps
I was having this same problem when I had an external HD connected directly to the Pi.
I bought a powered USB-hub to connect the HD (and keyboard/mouser) and now it works fine. No hangs.
I was having the same problem. Turns out that the USB WiFi adapter I had been using was causing problems in the powered USB hub I had plugged into my Raspberry Pi. Removing it fixed all the problems.
I'm having the same problem, I just recently transferred Raspbmc onto an external hard drive (so the system is on /dev/sda1), the system seemed to be much faster at first, but now after I navigate in the menu (changing screens) once or twice the front end hangs indefinitely.
I can still access ssh without any problems, topdoesn't report anything suspect, xmbc remains at a constant 6-7%.
This is the latest install, it constantly tells me it fails loading autostart.py after boot on xbmc screen, I can navigate the menu about twice and then it fails loading the next screen. It's really strange as it worked fine yesterday, it hanged maybe once, but not systematically.
