I'm trying to install Docker on a Raspberry Pi 3.
I followed the instructions and ran:
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
When I do this, I get the following error:
# Executing docker install script, commit: 2f4ae48
+ sh -c apt-get update -qq >/dev/null
E: The repository 'https://download.docker.com/linux/raspbian 10 Release' does not have a Release file.
I've tried to modify the docker.list file located at:
/etc/apt/sources.list.d
The file contains deb [arch=armhf] https://download.docker.com/linux/raspbian 10 stable, but I understand that this file is downloaded/replaced when I run the previous commands. I also took a look at /etc/apt/sources.list but there is just 1 deb and it is related to Raspberry Pi. Nevertheless, commenting it out did not solve anything.
I navigated with my web browser to https://download.docker.com/linux/raspbian and I can see there is a directory there called dists. I tried replacing:
with:
https://download.docker.com/linux/raspbian/dists/stretch 10 stable
but I just the same no release file error when I try to run sh get-docker.sh again...
Does anyone have any ideas?
Edit:
I can install Docker using the .deb files but the solution posted on the Docker website is incorrect.
Rich C
This appears to be an issue with lack of support for Raspbian 10 (buster) on Docker's site, however you can use this workaround for now (worked for me):
sudo curl -sL https://get.docker.com | sed 's/9)/10)/' | sh
MagicMicky
  • 103
