NOTE: Using the Arduino Uno
I am WORKING on a project that I have to submit in a few days. My arduino was all set up and was working fine.
Project:Arduino controls a 9v motor depending on the command given. As the arduino only provides 5v , i added a 9v battery to it through a transistor
I decided to add new code into the arduino but when I tried it failed. I have uploaded code thousands of times before (successfully) all of a sudden the IDE keeps giving the following message
avrdude: ser_open(): can't open device "\.\COM3": Access is denied.
I have looked up for a lot of solutions on this forum and elsewhere. Here are the things I have tried so far:
  1. Changing the COM port
  2. Disabling all the other devices CONNECTED to COM
  3. Tightening the CONNECTIONS
  4. Re installing all the drivers and the IDE
  5. Rebooting the system
  6. Using another laptop to upload code
All the above have given me the same output for some reason. The built in LED light and the power LED switch on when the board is CONNECTED to a power source (my laptop). Could the board have been damaged by any chance ? How can I check if the board is spoilt ? Should I buy a new board ?
Nick Gammon
  • 38,901
m0bi5
5 Answers5
I have a post Have I bricked my Arduino Uno? Problems with uploading to board - that describes various tests you can carry out to isolate where the problem is.
Nick Gammon
  • 38,901
Have you tried changing the Microprocessor in the Arduino Uno? An AtMega320P is much cheaper than new Arduino, and usually only the microprocessor gets spoilt, rest of the board remains intact.
Mathsman 100
  • 339
Could be the OS not allowing the application to access the COM ports, there is a terminal command to give the Arduino IDE access to the specific COM port.
  1. Remove all device connect to uno, and upload code to uno. Because, your device like motor will confuse uno.
  2. Check you usb to serial device.
  3. Check your uno
SivaCoHan
Check the device that the IDE says you're connected to.
http://forum.arduino.cc/index.php?topic=51489.0
