How to calibrate the internal RC oscillator off of a 32768 Hz crystal serving Timer2?
void OSCCAL_calibrate(void) //This version specific to ATmegaXX8 (tested with ATmega328)
unsigned char calibrate = 0; //FALSE;
uint16_t temp;
TIMSK1 = 0; //disable Timer1,2 interrupts
TIMSK2 = 0;
ASSR = (1 << AS2); //select asynchronous operation of timer2 (32,768kHz)
OCR2A = 200; // set timer2 compare value
TCCR1A = 0;
TCCR1B = (1 << CS11); // start timer1 with prescaler 8
TCCR2A = 0;
TCCR2B = (1 << CS20); // start timer2 with no prescaling (ATmega169 use TCCR2A!)
while (ASSR & ((1 << TCN2UB) | (1 << TCR2BUB))); //wait for TCN2UB and TCR2BUB to be cleared
delay(5000); //5 seconds to allow xtal osc to stabilize - does not work from main()
while (!calibrate)
cli(); // disable global interrupts
TIFR1 = 0xFF; // clear TIFR1 flags
TIFR2 = 0xFF; // clear TIFR2 flags
TCNT2 = 0; // clear timer2 counter
TCNT1 = 0; // clear timer1 counter
while ( !(TIFR2 & (1 << OCF2A)) ); // wait for timer2 compareflag
TCCR1B = 0; // stop timer1
sei(); // enable global interrupts
if ( (TIFR1 & (1 << TOV1)) ) temp = 0xFFFF; //overflow, load max
else temp = TCNT1;
if (temp > 6150) //expect about (1e6/32768)*201 = 6134 ticks
OSCCAL--; //RC oscillator runs too fast, decrease OSCCAL
else if (temp < 6120)
OSCCAL++; //RC oscillator runs too slow, increase OSCCAL
else calibrate = 1; //done
TCCR1B = (1 << CS11); // (re)start timer1
} //end while(!calibrate)
} //return
void setup(void)
EEPROM.put(0x1FD, 0xFFFF);
OSCCAL_calibrate();
EEPROM.put(0x1FD, OSCCAL);
void loop() { }
I write my value to the EEPROM then use it in another program; it causes all the communications not to work anymore (after I have set all my constants to the expected values for a ~ 8MHz clock). This is not for an Arduino but for an Atmega88PB - could not find anything special about it in the datasheet. FWIW, factory value = 0x96, algorithm value = 0x61.
edit Test setup and code:
First Board = signal generator:
ATMEGA328P with 8 MHz, +/- 30 ppm crystal, (room temperature)
TCCR2A = TCCR2B = 0;
/* Timer Clock = 8 MHz / 1 /
TCCR2B = (0<<CS22)|(0<<CS21)|(1<<CS20); // no prescales, counts 256 times for 32 useconds
/ Clear pending interrupts */
TIFR2 = (1 << TOV2) | (1 << OCF2A) | (1 << OCF2B);
TIMSK2 = (1 << TOIE2); // enable ovf interrupt
DDRB |= (1 << PB1); // pinMode(PIN_CS, OUTPUT);
PORTB |= (1 << PB1);
ISR (TIMER2_OVF_vect) // need it to catch our overflows
PORTB ^= (1 << PB1); //keep the radio chip asleep
// put your main code here, to run repeatedly:
Second Board = signal counter DUT:
ATMEGA168PB with 32768 Hz, +/- 20 ppm crystal, (room temperature)
Counting through clk_i/o based Timer2
#include <EEPROM.h>
#undef F_CPU
#define F_CPU 8000000L
#define PIN_WUP PD2
volatile bool fWUP = false;
volatile bool fOvfT2 = false;
volatile unsigned long cntWUP = 0;
ISR (PCINT2_vect) // handle Atmega328P precise signal
if (PIND & (1 << PIN_WUP))
fWUP = false;
} else {
fWUP = true;
cntWUP++;
TIMSK2 = (1 << TOIE2); // enable ovf interrupt > }
ISR (TIMER2_OVF_vect) // need it to count our overflows
{ fOvfT2 = true; }
EEPROM.put(0x1E6, 0xffff);
OSCCAL = 0x61;
PCMSK2 |= (1<<PCINT18); // aka PD2, PIN_WUP
PCICR |= (1<<PCIE2);
PCIFR |= (1<<PCIF2);
DDRD &= ~(1 << PIN_WUP);
PORTD &= ~(1 << PIN_WUP); // disable pullup
TCNT2 = 0;
TCCR2B = (0<<CS22)|(1<<CS21)|(1<<CS20); // 1/32 prescales, count at 1/4 MHz
void loop() { // put your main code here, to run repeatedly:
static unsigned long cntt2 = 0;
if (fOvfT2)
fOvfT2 = false;
cntt2++;
if (100000 == cntWUP) // 6.4 seconds, precise from Atmega328P
EEPROM.put(0x1E6, (cntt2 << 8) + TCNT2); // let's see how many ticks there have been
while (1) { } ;
The results are consistent across multiple runs:
running the codes above: eeprom value = 1,249,608; expected ticks = 1.6M => ratio = 0.781005
running with the
OSCAL = 0x61line commented out: eeprom value = 1,596,554; expected ticks = 1.6M => ratio = 0.99784625
OSCCALincorrectly sometimes but if the calibration was repeated immediately it would turn out a valuable that was slightly better than the factory one. At some point I may return to it. About the only thing I have offer now is thatASSRhas a flag for synchronizingOCR2Awhich you aren't using. I don't have specific reason to think that's the cause though. – timemage Aug 18 '25 at 19:38
