Testing the DAC on the Feather M4 Express (SAMD51 microcontroller). Tried to generate a square wave with the DAC.
  analogWriteResolution(12);
  analogWrite(A0, 0);
  delay(1);
  analogWrite(A0, 4095);
  delay(1);
I observe this DAC output. I tried it on two separate Feather M4 boards, and I get the staircase steps on both. What's causing it?
oscilloscope screenshot
update:
Similar question with staircase DAC waveforms, but no answer there.
misk94555
  • 133
I think I've replicated the problem and somewhat mitigated it:
Trace Comparison
You might be able to mess with the GCLK_DAC. But changing the DAC output current through DAC->DACCTRL[dac_channel].bit.CCTRL seems to be an option.
The datasheet has a table like this.
Value Name Description
0x0 CC100K GCLK_DAC ≤ 1.2MHz (100kSPS)
0x1 CC1M 1.2MHz < GCLK_DAC ≤ 6MHz (500kSPS
0x2 CC12M 6MHz < GCLK_DAC ≤ 12MHz (1MSPS)
I printed out the default under the Adafruit samd51 support, and it reported as CC100K.
Code to change the setting:
// dac-current.h
#include "sam.h"
enum class dac_current_setting : unsigned { CC100K = DAC_DACCTRL_CCTRL_CC100K_Val, // 0 macros defined CC1M = DAC_DACCTRL_CCTRL_CC1M_Val, // 1 by the atmel dac cmsis component header CC12M = DAC_DACCTRL_CCTRL_CC12M_Val, // 2 };
inline const char *dac_current_setting_str( const dac_current_setting setting ) { switch (setting) { case dac_current_setting::CC100K: return "CC100K"; case dac_current_setting::CC1M : return "CC1M"; case dac_current_setting::CC12M : return "CC12M"; } return "unknown"; }
inline void set_dac_output_current( const size_t dac_channel, dac_current_setting new_setting ) { if (dac_channel >= 2) { abort(); }
while (DAC->SYNCBUSY.bit.ENABLE || DAC->SYNCBUSY.bit.SWRST); DAC->CTRLA.bit.ENABLE = 0; while (DAC->SYNCBUSY.bit.ENABLE);
DAC->DACCTRL[dac_channel].bit.CCTRL = static_cast<unsigned>(new_setting);
DAC->CTRLA.bit.ENABLE = 1; while (DAC->SYNCBUSY.bit.ENABLE); }
Your code modified to allow the setting to be changed live by entering digits 0, 1, and 2:
#include "dac-current.h"
void set_and_report_setting(dac_current_setting new_setting) { set_dac_output_current(0, new_setting); Serial.print("CHANGED DAC->DACCTRL[0].bit.CCTRL to "); Serial.print(dac_current_setting_str(new_setting)); Serial.println(); }
void await_serial_connection() {while(!Serial);}
void setup() { Serial.begin(9600); await_serial_connection();
// Start out with high current. set_and_report_setting(dac_current_setting::CC12M); analogWriteResolution(12); }
void loop() { const int c = Serial.read(); // enter 0, 1, or 2 to change current mode if (c >= '0' && c <= '2') { const auto new_setting = static_cast<dac_current_setting>(c - '0'); set_and_report_setting(new_setting); }
analogWrite(A0, 0); delay(1); analogWrite(A0, 4095); delay(1); }
Default DAC clock rate
I'll figure out how to make sure that the DAC clock is 12 MHz.
The Adafruit SAMD51 board package apparently has already configured this for 12 MHz. So, it does seem strange that they're also using CC100K. In short they are taking the 48 MHz DPLL and dividing that by 4. There doesn't appear to be any further division of the clock, besides the by-12 division for TCONV.
But if you don't want to take my word for it, here's code to dump relevant clock configuration information (most of these names come from the samd51 CMSIS component/gclk.h:
auto &S = Serial; //to shorten code block
// // Constants // S.print("DAC_GCLK_ID : ");
S.println(DAC_GCLK_ID, DEC); S.print("GCLK_GENCTRL_SRC_DFLL_Val: "); S.println(GCLK_GENCTRL_SRC_DFLL_Val, DEC); S.println();
// // Relevant PCHCTRL // const auto &p/chctrl/ = GCLK->PCHCTRL[DAC_GCLK_ID]; S.print("<pchctrl>.bit.CHEN : "); S.println(p.bit.CHEN , DEC); S.print("<pchctrl>.bit.GEN : "); S.println(p.bit.GEN , DEC); S.println();
// // Relevant GENCTRL // const auto &g/enctrl/ = GCLK->GENCTRL[p.bit.GEN]; S.print("<genctrl>.bit.GENEN : "); S.println(g.bit.GENEN , DEC); S.print("<genctrl>.bit.SRC : "); S.println(g.bit.SRC , DEC); S.print("<genctrl>.bit.DIVSEL: "); S.println(g.bit.DIVSEL, DEC); S.print("<genctrl>.bit.DIV : "); S.println(g.bit.DIV , DEC); S.println();
Annotated output:
DAC_GCLK_ID              : 42
GCLK_GENCTRL_SRC_DFLL_Val: 6  // 48 MHz DPLL GENCLK SRC VALUE
<pchctrl>.bit.CHEN : 1 // DAC peripheral clock is enabled <pchctrl>.bit.GEN : 4 // is connected to general clock index 4
<genctrl>.bit.GENEN : 1 // general clock is enabled <genctrl>.bit.SRC : 6 // (GCLK_GENCTRL_SRC_DFLL_Val) is derived from 48Mhz DPLL <genctrl>.bit.DIVSEL: 0 // interpret .DIV below as simple division <genctrl>.bit.DIV : 4 // divide by 4; 48 Mhz / 4 == 12 MHz.
Now, you could go further and prove to yourself that the 48 MHz PLL is really running at 48 MHz... I suppose. But, it's not going to be running faster. An I'll just tell you flatly that it is being used to derive timing for the USB peripheral and is necessarily 48 MHz. But if you want to prove that you can use the same techniques.
timemage
  • 5,639
  • 25
The DAC of the SAMD51 needs some time to reach the new value. This is not a simple R-2R converter, for example.
The data sheet is quite detailed, and chapter 47.6.2.4 shows this behavior (idealized as a curve while you see staircase steps):
the busybee
  • 2,408
