I assume the ESP is the HTTP server and the Raspberry Pi is the client.
What you plan to do is typically achieved by having the server provide
multiple “endpoints”. And endpoint is typically an URL path that elicits
a specific response, often depending on the HTTP method. For example:
The request GET / would provide the home page. This is a static
HTML file served by the ESP from its file system. It defines the UI
of your Web application, and may reference external resources
(images, CSS, JavaScript) that are also served statically. The
JavaScript code is the client-side of the application, and it issues
the other requests.
GET /stream would provide the raw video stream.
POST /servo would instruct the ESP to move the servo. The request
payload may look something like angle=42. Some people use GET
requests for this type of interaction: this would not conform to the
HTTP semantics, but may be useful if your libraries make it hard to
handle POST requests.
The way you implement this depends on the libraries you use. An HTTP
library would typically let you write a callback for an endpoint, and
then you tell it “whenever you get a POST request for the path
"/servo", please call this function of mine to handle the request”.
Check the API documentation of your libraries for details.
From the Raspberry Pi, you can test a POST endpoint with the -d (like
“payload data”) option of the curl command-line program:
server=... # IP address of the ESP server
curl $server/servo -d 'angle=42'
