For clock synchronization I want to implement a pulse counter on the Arduino Nano Every. There are two clock signals at 40-100 kHz, the Nano runs on 20 MHz. Nyquist says we need at least 2 times the sampling frequency, we're at 200 times. So I assume it's possible to program a reliable pulse counter.
Currently, I'm using attachInterrupt(digitalPinToInterrupt(pin), isr, RISING) to count the rising edges on A0 and A1 and periodically display them via Serial.print(). If I have a clock on a single pin, the right amount of edges is counted. But if I connect both pins, each pin counts only 50% to 70% of the rising edges. At the scope, the signal looks fine to me.
volatile unsigned long risingCount0 = 0;
volatile unsigned long risingCount1 = 0;
void isr0() { risingCount0++; }
void isr1() { risingCount1++; }
Serial.begin(9600);
pinMode(A0, INPUT_PULLUP);
pinMode(A1, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(A0), isr0, RISING);
attachInterrupt(digitalPinToInterrupt(A1), isr1, RISING);
static unsigned long lastPrintTime = 0;
int waitSec = 5;
if (millis() - lastPrintTime >= waitSec * 1000) {
lastPrintTime = millis();
unsigned long c0, c1;
noInterrupts();
c0 = risingCount0;
c1 = risingCount1;
interrupts();
Serial.print(c0);
Serial.print(" ");
Serial.println(c1);
This person says pin 2-5 works for them, but when using digital pins 2 and 3, instead only 10 or 100 results per second are counted. This puzzles me, because the docs also say the digital pins are fine for interrupts. Simultaneous interrupts should be stored as well.
Reading
How do interrupts work on the Arduino Uno and similar boards?,
I see that, e.g. millis() disables interrupts for a short time, so I assume something is preventing the interrupts from happening. Reducing serial prints also mitigates the issue somehow, but still doesn't fix it. Also, interrupts should just be handled after one another and ISRs writing a single variable should take only single microseconds.
Ideally, there's a solution that continuously measures and prints the result to serial to perform long term measurements. Still, I'm now implementing a version that alternatively prints and measures, to make sure serial prints don't influence the measurement.
Any suggestions for libraries, improving the existing code or all together different approaches are highly welcome. I added project-critique tag as suggested by the help page.
