I tested an MPU-6050 (GY-521) using an Arduino Nano. I used the I2CDevLib and opened the MPU6050_DMP6.ino with the Arduino IDE. I opened the MPUTeapot.pde Processing-file with Processing. A few changes was necessary to make it work:
MPU6050 mpu;
was changed into:
MPU6050 mpu(0x68);
Additionally I commented out this line:
#define OUTPUT_READABLE_YAWPITCHROLL
and uncommented this line:
#define OUTPUT_TEAPOT
When turning everything on, the arrow (Processing) would turn with 5 degrees/s clockwise around the z-axis (plus a very small amount around the other two axes). After about 20 seconds, it would stop, and turn around the x-axis pretty fast for 3 seconds. Then it would stop. Now, the gyroscope+accelerometer would work perfectly. This happens every time I test it.
This happens only when the gyroscope is perfectly still on the ground. It does not stabilize if I move it around. Only after it is left completely still, it'll stabilize after 23 seconds.
Is this how it should work, or is it a problem with the gyroscope? Could it even be caused by the I2CDevLib? Can anybody else confirm this?
