I'm searching for the path and the source code for the builtin (I think) function, name is: renderBitmap().
This function appears as a member of the ArduinoLEDMatrix class but its name doesn't appear in the cpp source code or .h files on my PC at Documents/Arduino/libraries.
As I see that the row access is in the opposite usual access (Up Down) I'm wondering if a supplementary function exists ?
Does somebody know where the source code is on my PC? I have to say that accessing to GitHub appears to me as too difficult, you know..!
Greenonline
  • 3,152
  • 36
  • 48
Franck
  • 25
renderBitmap() is not in your Documents/Arduino/libraries because it's part of a core Arduino library, not a user-installed one. You can find it here: On Windows (default installation):
C:\Users\<YourUsername>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\<platform>\libraries\LEDMatrix\src\
Replace with the board core you're using, like:
1.3.2 for mbed_nano
2.6.1 for mbed_rp2040
Example full path:
C:\Users\<YourName>\AppData\Local\Arduino15\packages\arduino\hardware\mbed\2.6.1\libraries\LEDMatrix\src\Arduino_LED_Matrix.cpp
The renderBitmap() function writes pixels to the display top-down, which might seem unusual if you’re used to bottom-up framebuffer addressing. The layout is actually designed to match the way the 5x7 LED matrix segments are wired on the board.
If you're interested in customizing the rendering (e.g., flipping rows/columns), you could:
Create your own function similar to renderBitmap()
Or preprocess your bitmap array before passing it. Here is an Arduino MPU6050 Interactive scrolling game on 32x8 Led Matrix. This may help you a bit. https://www.pcbway.com/project/shareproject/Arduino_MPU6050_Interactive_scrolling_game_on_32x8_Led_Matrix_f63885fe.html
tepalia
  • 168
Note: This community wiki answer can be deleted if chrisl posts an answer
Quoting chrisl's comment which seems to be the answer:
I found this file at github by searching for the name of the header file in addition to "github". renderBitmap is a define, which used loadPixels() (line 145).
You didn't find it in Documents/Arduino/libraries, because that folder is for the libraries, that you installed. But that header file belongs to the renesas core, so you will find it in the core packages
Greenonline
  • 3,152
  • 36
  • 48
