I was trying to display the readings of my dht11 sensor on the Blynk dashboard but I am struggling a lot. A little help would be really appreciated.
#define BLYNK_PRINT Serial
/* Fill in information from Blynk Device Info here */ #define BLYNK_TEMPLATE_ID "TMPL3cu_fjr1u" #define BLYNK_TEMPLATE_NAME "DHT11 Example" #define BLYNK_AUTH_TOKEN "bpPlBa8ehOqw0sJLKJeO1thMlulVXUCY"
#include <DHT.h> #include <WiFi.h> #include <WiFiClient.h> #include <BlynkSimpleEsp32.h>
// Your WiFi credentials. // Set password to "" for open networks. char ssid[] = "*"; char pass[] = "*";
#define DHTPIN 2 // What digital pin we're connected to
// Uncomment whatever type you're using! #define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE); BlynkTimer timer;
// This function sends Arduino's up time every second to Virtual Pin (5) void sendSensor() { float h = dht.readHumidity(); float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) { Serial.println("Failed to read from DHT sensor!"); return; } // You can send any value at any time. // Please don't send more that 10 values per second. Blynk.virtualWrite(V5, h); Blynk.virtualWrite(V6, t); }
void setup() { // Debug console Serial.begin(9600);
dht.begin();
// Setup a function to be called every second timer.setInterval(1000L, sendSensor); }
void loop() { Blynk.run(); timer.run(); }
When I run this, it gets uploaded with no error, but Blynk shows that the device is offline and this is shown in the serial monitor of Arduino IDE:
15:38:20.658 -> ELF file SHA256: 4b7072eae
15:38:20.699 ->
15:38:20.735 -> Rebooting...
15:38:20.735 -> �[5001] Connecting to 0.0.0.0
15:38:26.059 ->
15:38:26.092 -> assert failed: xQueueSemaphoreTake queue.c:1709 (( pxQueue ))
15:38:26.181 ->
15:38:26.181 ->
15:38:26.181 -> Backtrace: (some lot of characters)
15:38:26.512 ->
15:38:26.512 ->
15:38:26.545 ->
15:38:26.545 ->
15:38:26.545 -> ELF file SHA256: 4b7072eae
15:38:26.578 ->
15:38:26.578 -> Rebooting...
15:38:26.614 -> ��[5001] Connecting to 0.0.0.0
15:38:35.107 ->
15:38:35.140 -> assert failed: xQueueSemaphoreTake queue.c:1709 (( pxQueue ))
15:38:35.206 ->
15:38:35.206 ->
15:38:35.206 -> Backtrace: (some lot of characters)
15:38:35.590 ->
15:38:35.590 ->
15:38:35.590 ->
15:38:35.590 ->
15:38:35.626 -> ELF file SHA256: 4b7072eae
15:38:35.626 ->
15:38:35.626 -> Rebooting...
15:38:35.668 -> �
Please help
Rohit Gupta
  • 618
Call Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass) to establish a WiFi connection first.
See ESP32_WiFi.ino example.
hcheung
  • 1,933
You're missing the Blynk.begin(auth, ssid, pass) call. Without it, Blynk never initializes properly, and that causes the queue/semaphore crash. The setup must look like this:
void setup()
  Serial.begin(9600);
  delay(1000); // Give time to serial to initialize
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass); dht.begin();
tepalia
  • 168
