I want to make a circuit that control speed of DC fan Using Arduino PID Library to get thing at specific temperature. enter image description here
The circuit looks like this but can be changed, The dc fan motor connected to PWM 3 and thermistor connected with pin A0.
The thermistor check the temperature of a device that heated by nearby heater so fan cools the device to get the specific temperature.
Case 1
When Heater not running, the thermistor value in Serial monitor 0-1023, When fan not running it gives 1023 and when fan runs at full speed it gives about 0.
Case 2
But when heater is running the values of thermistor has been changed and when fan not running it gives 1023 and when fan runs at full speed it gives about 500.
I want to set a point 650 from thermistor value(INPUT Value), and fan speed have to adjust using pid so temperature adjusted and the thermistor gives 650 value.
Sample PID code
 #include <PID_v1.h>
//Define Variables we'll be connecting to double Setpoint, Input, Output;
//Define the aggressive and conservative Tuning Parameters
double aggKp=4, aggKi=0.2, aggKd=1;
double consKp=1, consKi=0.05, consKd=0.25;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
void setup()
  Serial.begin(115200);
  //initialize the variables we're linked to
  Input = map(analogRead(0), 0, 1023, 255, 0);
  Setpoint = 650;
  myPID.SetOutputLimits(0, 255);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
void loop()
  int sensorValue = analogRead(0);
    double gap = abs(Setpoint-Input); //distance away from setpoint
  if(gap<10)
  {  //we're close to setpoint, use conservative tuning parameters
    myPID.SetTunings(consKp, consKi, consKd);
  else
     //we're far from setpoint, use aggressive tuning parameters
     myPID.SetTunings(aggKp, aggKi, aggKd);
  myPID.Compute();
  analogWrite(3,Output);
  Serial.println(sensorValue);
What changes have to done in code so we can set point from input values? And Please help me so this code works for me.
ANKIT JAIN
  • 185
5 Answers5
Two thing that may be helpful. First make sure you have a common ground. For instance for you transistor you are using separate power from the arduino and 12 volt source. Connecting the two ground of the arduino and the power supply may resolve this for you. The other thing is it is often times helpful to put a capacitor across the DC motor to help with voltage fluctuations.
First try using external power source to power the motor, as only very small motors can be connected to an Arduino's power source.(Basically, the Motor is using most of the power, leaving too little power for the Arduino to operate properly)
If that fails, change the code(I will give sample code by tomorrow, if you cannot find one yourself)-maybe use a PWM signal instead of trying PID, as it is much simpler and give very little room for error. And also, don't forget the fly back diode mentioned by Gerben.
Mathsman 100
  • 339
There are some issues with your map command.
For example, you are reading the thermistor value using analogRead(A0), which has a return range from 0 to 1023. After that you attempt to use map() to change this value to 0 - 255 but use the wrong syntax. The correct syntax for this command is Input = map(analogRead(0), 0, 1023, 0, 255);. However, I can't see the reason for that because you are reading values 0-1023, change it to 0-255, but set point is 650. So you never get setpoint because maximum is 255.
Try use as input just analogread(0). There is no reason to change input into PWM range and output is for PID library in PWM range as a default so you can send output direct to motor pin. Of course use some H-bridge or something like that.
per1234
  • 4,278
  • 43
Morfik
//Now it will work
//  https://arduino.stackexchange.com/questions/9731/control-speed-of-dc-fan-using-arduino-pid-library
#include <PID_v1.h>
double Setpoint, Input, Output;  //not there in original sketch
double aggKp = 4, aggKi = 0.2, aggKd = 1;
double consKp = 1, consKi = 0.05, consKd = 0.25;
//double consKp=2, consKi=5, consKd=1;
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, REVERSE);
void setup()
  Serial.begin(9600);
  // Input = map(analogRead(0), 0, 1023, 255, 0);
  //int val = analogRead(0);
  //val = map(val, 0, 1023, 0, 255);
  // analogWrite(9, val);
  Setpoint = 100;
  myPID.SetOutputLimits(0, 255); //MIN,MAX
  //turn the PID on
  myPID.SetMode(AUTOMATIC);  // MANUAL
  myPID.SetControllerDirection(REVERSE);  // DIRECT
void loop()
  Input = map(sensorValue, 0, 1023, 0, 255);
  double gap = abs(Setpoint - Input); //distance away from setpoint
  if (gap < 10)
  else
  myPID.Compute();
  analogWrite(3, Output);
  Serial.print(" PWM = ");
  Serial.print(Output,0);
  Serial.print("       sensor value =  ");
  Serial.print(sensorValue);
  Serial.print("       Input =");
  Serial.println(Input,0);
sempaiscuba
  • 1,042
RAJU
It may be better to not use map(), as it will give trouble between float and int variable usage - do it manually in the code.
Greenonline
  • 3,152
  • 36
  • 48
