There is a simple PlatformIO sketch (arduino format) that has the following main.cpp file:
#include <Arduino.h>
#include "esp_camera.h"
#include "camera_pins.h"
#define CAMERA_MODEL_AI_THINKER
#define LED_BUILTIN 33 // Define LED_BUILTIN for ESP32
void setup()
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(115200);
delay(500);
Serial.println("Camera initialising...");
camera_config_t config;
// Declaring pins in the config
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sccb_sda = SIOD_GPIO_NUM; // Replaced `sscb` with `sccb`
config.pin_sccb_scl = SIOC_GPIO_NUM; // Replaced `sscb` with `sccb`
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000; // Can be set to 10000000 for slower refresh rate but could lead to stable (slower) execution
config.pixel_format = PIXFORMAT_JPEG;
// Initialize the camera
if (psramFound())
Serial.println("PSRAM FOUND! Setting framesize to QVGA");
config.frame_size = FRAMESIZE_QVGA; // 320x240 resolution
config.jpeg_quality = 10;
config.fb_count = 2;
else
Serial.println("PSRAM NOT FOUND! Setting framsize to CIF");
config.frame_size = FRAMESIZE_CIF;
config.jpeg_quality = 20; // not 12 (0-63; lower means high quality)
config.fb_count = 1;
esp_err_t err = esp_camera_init(&config);
/* PSRAM NOT FOUND! Setting framsize to CIF
E (650) cam_hal: cam_dma_config(301): frame buffer malloc failed
E (650) cam_hal: cam_config(385): cam_dma_config failed
E (651) camera: Camera config failed with error 0xffffffff
Camera init failed with error 0xffffffff */
if (err != ESP_OK)
Serial.printf("Camera init failed with error 0x%x\n", err);
return;
Serial.println("Camera initialized successfully!");
void loop()
if (Serial.available())
String rcvdTxt = Serial.readString();
Serial.print("I heard: ");
Serial.println(rcvdTxt);
digitalWrite(LED_BUILTIN, HIGH);
// Serial.println("PING");
delay(1000);
digitalWrite(LED_BUILTIN, LOW);
// Serial.println("PONG");
Now the camera pins are set as per this article (pretty detailed article, I recommend checking out).
But the problem arises when I upload the code and start it up. The esp_camera_init(&config) chunk of code throws the following error:
Also, the psramFound() returns false, meaning the PSRAM is not detected.
