I build a PCB using ESP32-S3-WROOM-1-N16R2 Controller. I programmed a BME680 sensor with this MCU. My pinouts are,
BME_SCK 38
BME_MISO 19
BME_MOSI 15
BME_CS 5
This is my Arduino code,
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#define BME_SCK 38
#define BME_MISO 19
#define BME_MOSI 15
#define BME_CS 5
#define SEALEVELPRESSURE_HPA (1013.25)
//Adafruit_BME680 bme(&Wire); // I2C
//Adafruit_BME680 bme(&Wire1); // example of I2C on another bus
//Adafruit_BME680 bme(BME_CS); // hardware SPI
Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
Serial.begin(9600);
while (!Serial);
SPI.begin(BME_SCK, BME_MISO, BME_MOSI, BME_CS);
SPI.setDataMode(SPI_MODE0); // Set SPI mode (0, 1, 2, or 3)
Serial.println(F("BME680 test"));
if (!bme.begin()) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
} else {
Serial.println("BME680 sensor initialized successfully.");
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
if (! bme.performReading()) {
Serial.println("Failed to perform reading :(");
return;
Serial.print("Temperature = ");
Serial.print(bme.temperature);
Serial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bme.pressure / 100.0);
Serial.println(" hPa");
Serial.print("Humidity = ");
Serial.print(bme.humidity);
Serial.println(" %");
Serial.print("Gas = ");
Serial.print(bme.gas_resistance / 1000.0);
Serial.println(" KOhms");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
Serial.println();
delay(2000);
I got output like,
R~�g�BME680 test
R~R~�g�BME680 test
R~�g�R��g�BME680 test
I go through the ESP32-S3 datasheet, It says Any GPIO pins, we will assign for SPI, I2C Communications. Datasheet link for your reference, https://www.espressif.com/sites/default/files/documentation/esp32-s3-wroom-1_wroom-1u_datasheet_en.pdf ESP32-S3 series datasheet, https://www.espressif.com/sites/default/files/documentation/esp32-s3_datasheet_en.pdf
and also i wired the same pins in ESP32-S3 EVK and programmed with BME680, it gives data perfectly, I don't know what's the issue. How to solve this issue?
