I'm trying to create an arduino code that returns a value for the button that was pressed as the user choice. However, whichever button I press the only return is 2. Also, whenever pressing other buttons, button 2 is the one that seems to have been pressed.
What could it be? Any ideas on how to solve this issue?
This is the current code I have.
#include <MCUFRIEND_kbv.h>
#include <TouchScreen.h>
#define MINPRESSURE 500 #define MAXPRESSURE 2000 #define PRETO 0x0000 #define VERMELHO 0xF800 #define VERDE 0x07E0 #define BRANCO 0xFFFF
#define XP 6 #define XM A2 #define YP A1 #define YM 7
#define TS_LEFT 945 #define TS_RT 221 #define TS_TOP 916 #define TS_BOT 201
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300); Adafruit_GFX_Button botoes[4]; MCUFRIEND_kbv tft;
int posX, posY; int escolha = 0;
bool obterToque(void) { TSPoint p = ts.getPoint(); pinMode(YP, OUTPUT);
pinMode(XM, OUTPUT); digitalWrite(YP, HIGH);
digitalWrite(XM, HIGH); bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE); if (pressed) { posX = map(p.x, TS_LEFT, TS_RT, 0, 320); posY = map(p.y, TS_TOP, TS_BOT, 0, 240); // Debugging: Print the raw and mapped touch coordinates //Serial.print("Raw X: "); Serial.print(p.x); Serial.print(", Raw Y: "); Serial.println(p.y); //Serial.print("Mapped X: "); Serial.print(posX); Serial.print(", Mapped Y: "); Serial.println(posY); return true; } return false; }
void setup() { Serial.begin(9600); uint16_t ID = tft.readID(); tft.begin(ID); tft.setRotation(3); telaInicial(); }
void telaInicial(){ tft.fillScreen(PRETO); botoes[0].initButton(&tft, 160, 40, 250, 40, BRANCO, VERDE, PRETO, "1. Normal Sinus", 2); botoes[1].initButton(&tft, 160, 95, 250, 40, BRANCO, VERDE, PRETO, "2. Atrial Fibrillation", 2); botoes[2].initButton(&tft, 160, 150, 250, 40, BRANCO, VERDE, PRETO, "3. Ventricular Ectopy", 2); botoes[3].initButton(&tft, 160, 205, 250, 40, BRANCO, VERDE, PRETO, "4. SV Arrhythmia", 2);
for (int i = 0; i < 4; i++) { botoes[i].drawButton(false); } }
void TeclaPressionada(bool teclaTocada) { for (int i = 0; i < 4; i++) { botoes[i].press(teclaTocada && botoes[i].contains(posX, posY)); } checkPressedButton(); }
void checkPressedButton() { for (int i = 0; i < 4; i++) { if (botoes[i].justPressed()) { checkPressed(i); } } }
void esperaSoltar() { while (obterToque()) { delayMicroseconds(50); } }
void checkPressed(int button) { botoes[button].drawButton(true); esperaSoltar(); botoes[button].drawButton();
if (button == 0) {
    escolha = 1;
} else if (button == 1) {
    escolha = 2;
} else if (button == 2) {
    escolha = 3;
} else if (button == 3) {
    escolha = 4;
Serial.print(&quot;Escolha: &quot;);
Serial.println(escolha);
void loop() { bool toque = obterToque(); TeclaPressionada(toque); }
Thanks for reading.
I managed to find an answer on this video tutorial: https://www.youtube.com/watch?v=wn-1hHjRyjo
Here's the screen project I'm working on.
#include <Adafruit_GFX.h>
MCUFRIEND_kbv tft;
// Definição de cores #define BLACK 0x0000 #define BLUE 0x2015 #define BLUE2 0x0DDE #define RED 0xF800 #define GREEN 0x07E0 #define CYAN 0x07FF #define MAGENTA 0xF81F #define YELLOW 0xFFE0 #define WHITE 0xFFFF #define GREY 0xC639
// Variáveis Globais uint32_t startRead = 0; int page = 0; int posX; int posY;
// Variables for ECG data float ecgValue = 0.0; // Current ECG value received from serial int scale = 75; // Scale factor for voltage values int startY; // Vertical center for the waveform int ecgIndex = 0; // Current index for plotting int xPos = 0; // Horizontal position to draw the next data point int choice = 0; // User rhythm selection variable to lead to desired rhythm
#define MINPRESSURE 10 #define MAXPRESSURE 1000
void setup(void) { Serial.begin(115200); Serial.println("TFT Test"); tft.reset(); delay(500); uint16_t identifier = tft.readID(); tft.begin(identifier); tft.setRotation(1); tft.setCursor(0, 0); tft.setTextColor(BLACK); tft.setTextSize(2);
tft.println("Programa feito por: "); tft.println("Giovanne Lucas"); tft.println("Barreto"); tft.println("giovanne.pinto@medicina.uniceplac.edu.br");
delay(2000); tft.fillScreen(BLACK);
displayBootScreen(); delay(5000);
telainicial(); page = 0;
startY = tft.height() / 2; // Calculate vertical center for ECG plotting }
void displayBootScreen() { int screenWidth = tft.width(); int screenHeight = tft.height(); tft.drawBitmap(0, 0, bootImage, screenWidth, screenHeight, WHITE); delay(5000); tft.fillScreen(0x0000); // Placeholder: Fill screen with black tft.setTextColor(0xFFFF); tft.setTextSize(2); //tft.setCursor(10, screenHeight / 2 - 10); //tft.print("Booting..."); }
void telainicial() { tft.fillScreen(WHITE); tft.fillRoundRect(5, 5, 310, 30, 0, BLACK); tft.fillRoundRect(7, 7, 306, 26, 0, BLUE); tft.setCursor(120, 10); tft.setTextColor(WHITE); tft.setTextSize(3); tft.print("MENU");
tft.fillRoundRect(50, 55, 220, 40, 0, BLACK); tft.fillRoundRect(52, 57, 216, 36, 0, GREY); tft.setCursor(60, 65); tft.setTextColor(BLACK); tft.setTextSize(1); tft.print("1. Ritmo Sinusal");
tft.fillRoundRect(50, 115, 220, 40, 0, BLACK); tft.fillRoundRect(52, 117, 216, 36, 0, GREY); tft.setCursor(60, 124); tft.setTextColor(BLACK); tft.setTextSize(1); tft.print("2. Fibrilacao Atrial");
tft.fillRoundRect(50, 175, 220, 40, 0, BLACK); tft.fillRoundRect(52, 177, 216, 36, 0, GREY); tft.setCursor(60, 185); tft.setTextColor(BLACK); tft.setTextSize(1); tft.print("3. Ectopia Ventricular"); }
void tela1() { tft.fillScreen(WHITE); tft.fillRoundRect(5, 5, 310, 30, 0, BLACK); tft.fillRoundRect(7, 7, 306, 26, 0, BLUE); tft.setCursor(120, 10); tft.setTextColor(WHITE); tft.setTextSize(1); tft.print("Ritmo Sinusal");
tft.fillTriangle(30, 20, 50, 30, 50, 10, GREY); // Botão de voltar }
void tela2() { tft.fillScreen(WHITE); tft.fillRoundRect(5, 5, 310, 30, 0, BLACK); tft.fillRoundRect(7, 7, 306, 26, 0, BLUE); tft.setCursor(90, 10); tft.setTextColor(WHITE); tft.setTextSize(1); tft.print("Fibrilacao Atrial");
void tela3() { tft.fillScreen(WHITE); tft.fillRoundRect(5, 5, 310, 30, 0, BLACK); tft.fillRoundRect(7, 7, 306, 26, 0, BLUE); tft.setCursor(90, 10); tft.setTextColor(WHITE); tft.setTextSize(1); tft.print("Ectopia Ventricular");
void tela4() { tft.fillScreen(WHITE); tft.fillRoundRect(5, 5, 310, 30, 0, BLACK); tft.fillRoundRect(7, 7, 306, 26, 0, BLUE); tft.setCursor(90, 10); tft.setTextColor(WHITE); tft.setTextSize(1); tft.print("Arritmia Supraventricular");
void plotECG() { static int xPos = 0; // horizontal position to draw the next data point static int startY = tft.height() / 2; // vertical center for the waveform static int lastY = startY; // previous Y coordinate
if (Serial.available() > 0) { float ecgValue = Serial.parseFloat(); int y1 = startY - (int)(ecgValue * scale); // calculate Y coordinate based on ECG value
// draw a line from the previous point to the current point
tft.drawLine(xPos - 1, lastY, xPos, y1, RED);
// update lastY and xPos for the next loop iteration
lastY = y1;
xPos = (xPos + 1) % tft.width(); // wrap xPos around the screen width
// clear the screen and redraw the grid if necessary
if (xPos == 0) {
  tft.fillScreen(WHITE); // clear the screen
  drawECGGrid(); // redraw the grid
void loop() { TSPoint p = ts.getPoint(); pinMode(XM, OUTPUT); digitalWrite(XM, LOW); pinMode(YP, OUTPUT); digitalWrite(YP, HIGH); pinMode(YM, OUTPUT); digitalWrite(YM, LOW); pinMode(XP, OUTPUT); digitalWrite(XP, HIGH);
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) { posX = map(p.y, TS_LEFT, TS_RT, 0, 320); posY = map(p.x, TS_TOP, TS_BOT, 0, 240);
if (page == 0) {
  if (posX &gt; 52 &amp;&amp; posX &lt; 268 &amp;&amp; posY &gt; 57 &amp;&amp; posY &lt; 93)  //RITMO SINUSAL
    page = 1;
    choice = 1;
    tela1();
    delay(50); // debounce
  if (posX &gt; 52 &amp;&amp; posX &lt; 268 &amp;&amp; posY &gt; 117 &amp;&amp; posY &lt; 153)  //FIBRILACAO ATRIAL
    page = 2;
    choice = 2;
    tela2();
  if (posX &gt; 52 &amp;&amp; posX &lt; 268 &amp;&amp; posY &gt; 177 &amp;&amp; posY &lt; 213)  //ECTOPIA VENTRICULAR
    page = 3;
    choice = 3;
    tela3();
} else {
  // Verifica o botão de voltar
  if (posX &gt; 30 &amp;&amp; posX &lt; 50 &amp;&amp; posY &gt; 10 &amp;&amp; posY &lt; 30)  //botão voltar
    telainicial();
    page = 0;
} if (page == 1) { plotECG(); // Ritmo Sinusal } else if (page == 2) { plotECG(); // Fibrilação Atrial } else if (page == 3) { plotECG(); // Ectopia Ventricular } else if (page == 4) { plotECG(); // Arritmia Supraventricular }
// Always send the choice value to the serial port Serial.print("Choice: "); Serial.println(choice);
// Function to draw the ECG grid void drawECGGrid() { int smallSquareSize = 10; // 10 pixels for small squares int largeSquareSize = 50; // 50 pixels for large squares
uint16_t smallGridColor = GREY; // Light grey color for small squares
uint16_t largeGridColor = 0x7BEF; // Darker grey color for large squares
// Draw the small squares
for (int x = 0; x &lt;= tft.width(); x += smallSquareSize) {
    tft.drawFastVLine(x, 0, tft.height(), smallGridColor);
for (int y = 0; y &lt;= tft.height(); y += smallSquareSize) {
    tft.drawFastHLine(0, y, tft.width(), smallGridColor);
// Draw the large squares
for (int x = 0; x &lt;= tft.width(); x += largeSquareSize) {
    tft.drawFastVLine(x, 0, tft.height(), largeGridColor);
for (int y = 0; y &lt;= tft.height(); y += largeSquareSize) {
    tft.drawFastHLine(0, y, tft.width(), largeGridColor);
