I have done a lot of reading and learning after previous help here and it has been great. I have uploaded and tried many iterations of my code which all worked (Assuming my code was actually good) and i though i had finally cracked my project today. I was writing a bunch at work without my ESP with me so i did a lot of changes and only uploaded it when i got home. The issue is, as soon as i did the ESP got stuck in a really short <500ms reboot loop. I had to ground GPIO0 to get it out of the loop and upload code that does work to get the ESP stable again. My previous versions upload and work as they did before but my latest version just gets it into the loop and i have to again ground GPOI0 to get out. I have compared as best as i know how and i cannot see how the code is so broken. It compiles correctly and the upload output has no errors. Please help.
Todays edits were mostly writing and editing the LED Logic, Timer Logic and Gate Logic
Purpous.
This project is a timer i have built for calculating the time and speed of a model rocket traveling along a cable. It would use 3 light gates (Currently buttons for dev). Gs is the start gate, G1 is the second gate but the first of the speed trap, G2 if the final gate. The first timer starts when the rocket leaves the first gate (Gs), When the rocket passes the second gate (First speed trap gate) (G1) a second timer starts. When it reaches the 3rd and final gate (G2), both timers stop and the system takes the time it took to travel between gate S and 2 to calculate average speed then the time between G1 and G2 to calculate the speed through the speed trap. Distance is entered in a "menu". I am still new to code this complex (Well for me it is) so i have no idea how it broke.
I can upload previous working versions if it would help.
#include <LiquidCrystal_I2C.h>
const int startPin = 12; // Start button Pin const int stopPin = 11; // Stop button Pin const int resetPin = 10; // Reset button Pin const int menuPin = 5; // Menu button Pin const int Gs = 6; // Start Gate (White) const int G1 = 7; // Finish Gate 1 Pin (Yellow) const int G2 = 8; // Finish Gate 2 Pin (Blue) const int ledr = 2; // Red LED Pin const int ledg = 3; // Green LED Pin const int ledy = 4; // Yellow LED Pin
bool WaitM = false; // Timer (Main) waiting for start bool WaitG = false; // Timer (Gate) waiting to start bool RunningM = false; // State of speed main timer bool RunningG = false; // State of speed gate timer bool Run = false; // Is timer program running? bool SysState = false; // Is system up? bool clearscreen = false; // Clear screen state bool menu = false; // Is the range menu active on the display
int ledgState = LOW; // the current state of the Green LED output pin int ledyState = LOW; // the current state of the Yellow LED output pin int ledrState = LOW; // the current state of the Red LED output pin
int startbuttonState; // the current reading from the start button input pin int startbuttonStateLatch = LOW; // start button latch state after debounce int laststartbuttonState = LOW; // the previous reading from the start button input pin int stopbuttonState; // the current reading from the stop button input pin int stopbuttonStateLatch = LOW; // stop button latch state after debounce int laststopbuttonState = LOW; // the previous reading from the stop button input pin int resetbuttonState; // the current reading from the reset button input pin int resetbuttonStateLatch = LOW; // reset button latch state after debounce int lastresetbuttonState = LOW; // the previous reading from the reset button input pin int menubuttonState; // the current reading from the menu button input pin int menubuttonStateLatch = LOW; // menu button latch state after debounce int lastmenubuttonState = LOW; // the previous reading from the menu button input pin
int GsState; // State of Start Gate sensor int lastGsState = LOW; // Last state of Stare Gate button (To be reomved when sensor replaced button) int G1State; // State of Gate 1 (speed trap start) Sensor int lastG1State = LOW; // Last state of G1 button (To be reomved when sensors replace buttons) int G2State; // Stage of Gate 2 (Speed trap and full run) sensor int lastG2State = LOW; // Last state of G2 button (To be removed when sensors replace buttons)
int Range = 50; // Range length input in M(eters) int TrapLength = 2; // Trap light gates distance apart in M(eters)
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled unsigned long debounceDelay = 25; // the debounce time; increase if the output flickers unsigned long StartMMillis; // millis at start if Main run unsigned long StartGMillis; // millis at start of speed trap unsigned long EndMillis; // millis at end of run unsigned long RunM; // millis time for main run unsigned long RunG; // millis time for speed trap unsigned int TrapS = 0; // Speed between Gate 2(B) & 3(C) (M/S) unsigned int TrapSMPH = 0; // Speed between Gate 2(B) & 3(C) (MPH) unsigned int SpeedAVG = 0; // Speed average between Gate 1(A) & 3(C)
LiquidCrystal_I2C lcd(0x27, 20, 4); // LCD setup
void setup() { Serial.begin(9600); // Start Serial
lcd.init(); // Start and config for LCD, backlight and cursor lcd.backlight(); lcd.setCursor(0,0);
pinMode(startPin, INPUT_PULLDOWN); // Pin setup for buttons, LED's and gate sensors pinMode(stopPin, INPUT_PULLDOWN); pinMode(resetPin, INPUT_PULLDOWN); pinMode(menuPin, INPUT_PULLDOWN); pinMode(Gs, INPUT_PULLDOWN); pinMode(G1, INPUT_PULLDOWN); pinMode(G2, INPUT_PULLDOWN); pinMode(ledr, OUTPUT); pinMode(ledg, OUTPUT); pinMode(ledy, OUTPUT);
digitalWrite(ledr, ledrState); // Output for LED's digitalWrite(ledg, ledgState); digitalWrite(ledy, ledyState);
Run = false; // Set RUN to false at start SysState = false; // Set System State to false at start
} void loop() {
                                                              // BUTTON DEBOUNCE LOGIC (Adding buttons as needed)
//Start Button debounce filter int readingstart = digitalRead(startPin); //Read state of button into local variable //Check to see if button was just pushed (Went from LOW to HIGH), And if you have waited long enough //since the last press to ignore any noise if (readingstart != laststartbuttonState) { //if the switch changed, due to noise or pressing, lastDebounceTime = millis(); //reset debouce millis timer } if ((millis() - lastDebounceTime) > debounceDelay ) { // whatever the reading is at, it's been there for longer than the debounce delay, so take it as the actual current state:
if (readingstart != startbuttonState) { // if the button state has changed: startbuttonState = readingstart;
if (startbuttonState == HIGH) {                                //only toggle filtered state if the new button state is HIGH
    startbuttonStateLatch = !startbuttonStateLatch;
} } laststartbuttonState = readingstart;
//Stop Button debounce filter int readingstop = digitalRead(stopPin); if (readingstop != laststopbuttonState) { lastDebounceTime = millis(); }
if (readingstop != stopbuttonState) {
  stopbuttonState = readingstop;
  if (stopbuttonState == HIGH) {
    stopbuttonStateLatch = !stopbuttonStateLatch;
} laststopbuttonState = readingstop;
//Reset Button debounce filter int readingreset = digitalRead(resetPin); if (readingreset != lastresetbuttonState) { lastDebounceTime = millis(); }
if (readingreset != resetbuttonState) {
  resetbuttonState = readingreset;
  if (resetbuttonState == HIGH) {
   resetbuttonStateLatch = !resetbuttonStateLatch;
} lastresetbuttonState = readingreset;
//menu Button debounce filter int readingmenu = digitalRead(menuPin); if (readingmenu != lastmenubuttonState) { lastDebounceTime = millis(); }
if (readingmenu != menubuttonState) {
  menubuttonState = readingmenu;
  if (menubuttonState == HIGH) {
   menubuttonStateLatch = !menubuttonStateLatch;
} lastmenubuttonState = readingmenu; // Once fitted, test lights sensors without debounce to reduce CPU load
//Gs button debaounce (No latch state required) int readingGs = digitalRead(Gs); if (readingGs != lastGsState) { lastDebounceTime = millis(); } if ((millis() - lastDebounceTime) > debounceDelay) { if (readingGs != GsState) { GsState = readingGs; } }
//G1 button debounce (No latch state required) int readingG1 = digitalRead(G1); if (readingG1 != lastG1State) { lastDebounceTime = millis(); } if ((millis() - lastDebounceTime) > debounceDelay) { if (readingG1 != G1State) { G1State = readingG1; } }
//G2 button debounce (No latch state required) int readingG2 = digitalRead(G2); if (readingG2 != lastG2State) { lastDebounceTime = millis(); } if ((millis() - lastDebounceTime) > debounceDelay) { if (readingG2 != G2State) { G2State = readingG2; } }
                                          // LED Logic
if (Run) { digitalWrite(ledg, HIGH); } else { digitalWrite(ledg, LOW); }
if (WaitM && !RunningM && WaitG && !RunningG){ digitalWrite(ledy, HIGH); } else { digitalWrite(ledy, LOW); }
if (!Run && !WaitM && !RunningM && !WaitG && !RunningG){ digitalWrite(ledg, LOW); digitalWrite(ledy, LOW); digitalWrite(ledr, HIGH); }
                                          // Gate LOGIC
if ((startbuttonState == HIGH) && (GsState == 1) && (G1State == 1) && (G2State == 1)) { //if start button & all 3 gate buttons are true then set both Wait, Run and SysState to true stopbuttonStateLatch = LOW; WaitM = true; WaitG = true; Run = true; SysState = true; }
if (stopbuttonState == HIGH) { // if stop button pressed, set Run to false, Keep SysState True startbuttonStateLatch = LOW; Run = false; SysState = true; }
if (resetbuttonState == HIGH) { // if reset button pressed, Run = false; // set Run and SysState to false, SysState = false; startbuttonStateLatch = LOW; // Set button latch to off and turn off LED's digitalWrite(ledg, LOW); stopbuttonStateLatch = LOW; digitalWrite(ledr, LOW); }
if ((GsState == 1) && (G1State == 1) && (G2State == 1)){ // if all 3 gates are true WaitM = true; // set both wait states to true RunningM = false; // set both Running states to false (Should be anyway in normal startup) WaitG = true; RunningG = false; }
if ((GsState == 0) && (G1State == 1) && (G2State == 1)){ // When first gate opens (State goes off) WaitM set to false WaitM = false; }
if ((GsState == 0) && (G1State == 0) && (G2State == 1)){ // When first and second gates open, WaitG (2nd) wait state goes false WaitG = false; }
if ((GsState == 0) && (G1State == 0) && (G2State == 0)){ // WHen final gate opens, set Run to false Run = false; }
                                                          // TIMER Logic
                                                //Rocket leaves start gate
if (Run && !WaitM && !RunningM){ StartMMillis = millis(); RunningM = true; } // Rocket passes first speed gate if (Run && !WaitG && !RunningG){ StartGMillis = millis(); RunningG = true; } // Rocket passes 2nd speed gate, ending run if (!Run && RunningM && RunningG){ EndMillis = millis(); RunningM = false; RunningG = false; }
// At end, calculate speed in M/s if (!Run && !RunningM && !RunningG) { RunM = (EndMillis - StartMMillis); RunG = (EndMillis - StartGMillis); TrapS = (TrapLength / RunG)/1000; TrapSMPH = TrapS * 2.237; SpeedAVG = ((Range / RunM)/1000)*2.237; }
                                                          // SCREEN OPTIONS
                                                          // RANGE ADJUST MENU
if (menubuttonStateLatch == HIGH) { menu = true; } else { menu = false; }
if(menubuttonState == HIGH) { lcd.clear(); }
if (menu) {
if(digitalRead(startPin) == HIGH){ Range = Range + 1; lcd.setCursor(0,2); lcd.print(" "); } if(digitalRead(stopPin) == HIGH){ Range = Range - 1; lcd.setCursor(0,2); lcd.print(" "); }
// lcd.clear(); lcd.setCursor(0,0); lcd.print("Range in full M"); lcd.setCursor(0,1); lcd.print(Range); }
                                                            // MAIN SCREEN WITH TIMER AND SPEED DISPLAY
else { lcd.setCursor(0,0); lcd.print("Run Time (ms)- "); lcd.print(RunM); lcd.setCursor(0,1); lcd.print("Speed (AVG) - "); lcd.print(SpeedAVG); lcd.setCursor(0,2); lcd.print("Speed (MAX) - "); lcd.print(TrapSMPH); lcd.setCursor(0,3); lcd.print("Gate|A"); lcd.print(digitalRead(Gs)); lcd.print("|B"); lcd.print(digitalRead(G1)); lcd.print("|C"); lcd.print(digitalRead(G2)); lcd.print("|");
if (!SysState && !Run) { lcd.print(" OFF "); } if (SysState && Run && WaitM && !RunningM) { lcd.print(" Wait "); } if (SysState && Run && !WaitM && RunningM) { lcd.print(" Run "); } if (SysState && !Run) { lcd.print(" Stop "); } } // Serial output Serial.print ("Button states : Mom|Lat : "); Serial.print ("Start = "); Serial.print (startbuttonState); Serial.print (startbuttonStateLatch); Serial.print (" || Stop = "); Serial.print (stopbuttonState); Serial.print (stopbuttonStateLatch); Serial.print (" || Reset = "); Serial.print (resetbuttonState); Serial.print (resetbuttonStateLatch); Serial.print (" || Menu = "); Serial.print (menubuttonState); Serial.print (menubuttonStateLatch); Serial.println("Gate States: "); Serial.print(" Gs (A)-"); Serial.print(digitalRead(Gs)); Serial.print(" || G1 (B)-"); Serial.print(digitalRead(G1)); Serial.print(" || G2 (C)-"); Serial.print(digitalRead(G2)); Serial.println ("System States: "); Serial.print("Menu:"); Serial.print (menu); Serial.print (" || Run = "); Serial.print (Run); Serial.print (" || System State = "); Serial.print (SysState); Serial.println ("Timer State: "); Serial.print ("WaitM = "); Serial.print (WaitM); Serial.print (" || RunningM: "); Serial.print (RunningM); Serial.print (" || WaitG: "); Serial.print (WaitG); Serial.print (" || RunningG: "); Serial.println (RunningG);
