I have a ESP32 with a web server. In the page where I show the sensor readings and the state of the system, right now the readings are showing themselves well. The problem comes when I want to show the state of the system.
Right now I'm testing the behavior only with the /encender page. The state of the system is sent in a JSON file to only update the elements that contains the system state. Instead of update those html elements, the page disappears and the web explorer shows me an error of empty response.
Here follows my actual code related to my problem:
Code related to the /encender page (an element) in backend.cpp:
server.on("/encender", HTTP_GET,[](AsyncWebServerRequest *request){
    digitalWrite(ledPinSistemaApagado,LOW);
    digitalWrite(ledPinSistemaEncendido,HIGH);
    if(ultimaPaginaCargada == "/encender");
      Serial.println("No se envía la página /encender, solo se actualizará el estado del sistema.");
      request->send(200);
      return;
    ultimaPaginaCargada = "/encender";
    cuentaAcceso = true;
    request->send(SPIFFS,"/index.html", String(), false, Procesador);
The code in backend.cpp related to the update of the state of the function is like follows:
server.on("/data-estado", HTTP_GET, [](AsyncWebServerRequest *request){
    if(!request->authenticate(usuarioHTTP, claveHTTP) && !cuentaAcceso) {
        return request->requestAuthentication("Ingreso al Sistema");
    Serial.println("Enviando la data de estado.");
    sistemaEstado["estado-sistema"] = ledEstado;
    sistemaEstado["modo-sistema"] = modoSistema;
    String json = "";
    serializeJsonPretty(sistemaEstado, json);
    Serial.println(json);
    ultimaPaginaCargada = "/data-estado";
    request->send(200, "application/json", json);
    json = String();
    Serial.println("Enviada la data de estado.");
Right now the above piece of code, if the variable ùltimaPaginaCargada is "/encender", it means that the page /encender was previously loaded, so it only sends "200" to the web explorer. On the contrary, the "/encender" wasn't previously loaded and that page is sent.
Following is the code on my app.js:
function Actualiza_Estado() {
    console.log("Entrando a Actualiza_Estado().");
    var xxhr = new XMLHttpRequest();
    if(this.readyState == 4 && this.status == 200)
        console.log("Analizando los componentes reibidos en Actualiza_Estado()");
        var estadoWeb = JSON.parse(this.responseText);
        console.log(estadoWeb);
        var estadoEnc = document.getElementById("estado-sistema");
        estadoEnc.innerHTML = "<p>Estado Sistema: " + "<strong>" + `${estadoWeb.estado-sistema}` + "</strong>";
        var modoEnc = document.getElementById("modo-sistema");
        modoEnc.innerHTML = "<p>Modo Sistema: " + "<strong>" + `${modoEnc.modo-sistema}` + "</strong>";
        console.log("Enviados los componentes a actualizar a la pantalla");
    else
        console.log("Contenido no cargado en Actualiza_Estado()");
xxhr.open(&quot;HTTP_GET&quot;, &quot;/data-estado&quot;, true);
xxhr.send();
console.log(&quot;Solicitada la actualización del estado del sistema&quot;);
// Funciones para mostrar el nivel del tanque en la página de visualización.
function Lee_Nivel_Tanque() { var xhr = new XMLHttpRequest(); xhr.onreadystatechange = function() { if(this.readyState == 4 && this.status == 200) { var volTanqueWeb = JSON.parse(this.responseText); console.log(volTanqueWeb); var volActualWeb = document.getElementById("mask01"); volActualWeb.innerHTML = volTanqueWeb.colAgua.toFixed(2); } else { console.log("Contenido no cargado en Lee_Nivel_Tanque()"); } }; xhr.open("HTTP_GET", "/data-tanque", true); xhr.send(); console.log("Solicitada actualización del tanque."); };
// Funciones para enviar la hora y la fecha a la ventana
function Fecha_Hora() { let hoyFecha = new Date(); let hoyHora = hoyFecha.toLocaleTimeString(); let dia = hoyFecha.getDate(); let mes = hoyFecha.getMonth() + 1; let anio = hoyFecha.getFullYear(); let diaSemana = hoyFecha.getDay(); dia = ('0' + dia).slice(-2); mes = ('0' + mes).slice(-2); let semana = ['DOMINGO', 'LUNES', 'MARTES', 'MIÉRCOLES', 'JUEVES', 'VIERNES', 'SÁBADO']; let muestraSemana = semana[diaSemana]; let fechaCompleta = ${muestraSemana}-${dia}-${mes}-${anio}; document.getElementById("la-fecha").innerHTML = fechaCompleta; document.getElementById("la-hora").innerHTML = hoyHora; console.log(fechaCompleta + '->' + hoyHora); };
window.onload = function() { let intervaloVolumen; let intervaloFecha; intervaloFecha = setInterval(Fecha_Hora, 1000); if((window.location.pathname === "/index") || (window.location.pathname === "/apagar") || (window.location.pathname === "/encender") || (window.location.pathname === "/auto") || (window.location.pathname === "/manual")) { //Actualiza_Estado(); intervaloVolumen = setInterval(Lee_Nivel_Tanque, 20000); } else { clearInterval(intervaloVolumen); intervaloVolumen = null; } }
var datoEstado = document.getElementsByClassName("boton-control"); datoEstado.addEventListener("click", function(event) { event.preventDefault(); Actualiza_Estado(); });
Above the functions that I think matters are Àctualiza_Estado() and the var datoEstado. datoEstado is basically a listener that when I make click at any of the buttons made with <a> elements it calls Àctualiza_Estado() to request the JSON file with the state of the system.
On the window.onload() function, if any of the buttons or the principal page are loaded then it defines an interval to update the parameter to read from the sensor and every 20 seconds, it requests a JSON file with that data (this works excellent).
Is that in the function server.on() related to /encender page? I make the program to send a 200 response to the request to make the ESP32 code to send only the JSON file by calling the Actualiza_Estado() function with requests /data-estado, but like I said the web explorer seems to have an empty response.
I've made a variation in the function server.on() related to /encender page in backend.cpp to force the sending of the JSON file directly from there like follows
    String json = "";
    json = String();
In the above case the web explorer receives the JSON file and displays de data but in an empty black page and shows the formatted JSON file.
I don't know whats happening because the method of JSON file. It works very well when using it for the sensor reading with Lee_Nivel_Tanque().
What can I do to solve the problem?
Gil Sven
  • 167
vram
I didn't go through all the question. Just looking at the code there are quite a few issues that deserve to be addressed.
In the back-end for /encender, you have
Notice the semicolon right after the condition. In C++, a bare semicolon is an empty statement (a no-op). Here, this empty statement is the body of the if statement. The braced block that follows is executed unconditionally. This is most likely not what you mean.
        request->send(200);
Do not send an empty 200 response. If you want to tell the client “your request has been processed successfully, but I have nothing to send to you”, you should send a 204 No Content response.
A Web API is supposed to be stateless. If you need to remember the last page loaded, your whole protocol is most likely flawed.
On the JavaScript function Actualiza_Estado():
    if (this.readyState == 4 && this.status == 200) {
The second line does not belong here: it should be within a onreadystatechange handler. See how Lee_Nivel_Tanque() is written.
Edit: A few more remarks.
I previously wrote “If you need to remember the last page loaded, your whole protocol is most likely flawed.” You may have misunderstood this point. The problem is not that the server remembers which page was loaded last. The problem is that its behavior depends on this information. The server response should not depend on what page was loaded last.
request->send(SPIFFS, "/index.html", String(), false, Procesador);
This looks fishy. I am not sure I fully understand your approach but, from the little you show, it looks to me like you are building a Web-based user interface for some device in the form of a single-page application. In this approach, you have:
  1. A single URL (typically the root: /) that delivers the user interface in the form of a static HTML document, possibly with embedded JavaScript.
  2. Zero or more URLs that deliver static assets required by that document: JavaScript, images, fonts…
  3. One or more endpoints that let you interact with the device by either retrieving JSON-formatted dynamic data (GET endpoints) or changing the device's state (POST endpoints).
In this approach, the only instance where you may serve an HTML document is in response to a GET / request. A dynamic data endpoint should never deliver index.html.
xxhr.open("HTTP_GET", "/data-estado", true);
The HTTP method should be written "GET", not "HTTP_GET".
Edgar Bonet
  • 45,094
  • 81
