I'm new to ESP32 development and I'm trying to compile a program in the Arduino IDE to record the vibrations by an ADXL345 sensor. However, during compilation, I encounter a "ModuleNotFoundError: No module named 'serial'" error which seems to be related to serial communication.
I'm using an ESP32 Dev Module with the Arduino IDE version 1.18.19 on Ubuntu 22.04 Jammy Here's the code I'm trying to compile :
* Example sketch for the ADXL345_WE library
* This sketch shows how use SPI for the basic data sketch. Please apply the
* same steps in the other sketches if you want to use SPI.
* Further information can be found on:
* https://wolles-elektronikkiste.de/adxl345-teil-1 (German)
* https://wolles-elektronikkiste.de/en/adxl345-the-universal-accelerometer-part-1 (English)
#include<ADXL345_WE.h>
#include<SPI.h>
#define CS_PIN 5 // Chip Select Pin
#define NUM_SAMPLES 3200
bool spi = true; // flag indicating that SPI shall be used
xyzFloat samples[NUM_SAMPLES];
ADXL345_WE myAcc = ADXL345_WE(CS_PIN, spi);
const int int2Pin = 22; // interrupt pin
volatile bool dataReady = false;
void setup(){
Serial.begin(921600);
Serial.println("ADXL345 Demo");
if(!myAcc.init()){
Serial.println("ADXL345 not connected!");
// Prepare int pin for input
pinMode(int2Pin, INPUT);
/* You can set the SPI clock speed. Default is 5 MHz. */
// myAcc.setSPIClockSpeed(4000000);
/* Choose the data rate Hz
ADXL345_DATA_RATE_3200 3200
ADXL345_DATA_RATE_1600 1600
ADXL345_DATA_RATE_800 800
ADXL345_DATA_RATE_400 400
ADXL345_DATA_RATE_200 200
ADXL345_DATA_RATE_100 100
ADXL345_DATA_RATE_50 50
ADXL345_DATA_RATE_25 25
ADXL345_DATA_RATE_12_5 12.5
ADXL345_DATA_RATE_6_25 6.25
ADXL345_DATA_RATE_3_13 3.13
ADXL345_DATA_RATE_1_56 1.56
ADXL345_DATA_RATE_0_78 0.78
ADXL345_DATA_RATE_0_39 0.39
ADXL345_DATA_RATE_0_20 0.20
ADXL345_DATA_RATE_0_10 0.10
myAcc.setDataRate(ADXL345_DATA_RATE_3200);
// Safety delay
delay(100);
Serial.print("Data rate: ");
Serial.print(myAcc.getDataRateAsString());
/* In full resolution the size of the raw values depend on the
range: 2g = 10 bit; 4g = 11 bit; 8g = 12 bit; 16g =13 bit;
uncomment to change to 10 bit for all ranges.
// myAcc.setFullRes(false);
/* Choose the measurement range.
ADXL345_RANGE_16G 16g
ADXL345_RANGE_8G 8g
ADXL345_RANGE_4G 4g
ADXL345_RANGE_2G 2g
myAcc.setRange(ADXL345_RANGE_4G);
Serial.print(" / g-Range: ");
Serial.println(myAcc.getRangeAsString());
Serial.println();
// Define interrupt routine and move data_ready to adxl int2
attachInterrupt(digitalPinToInterrupt(int2Pin), dataReadyISR, RISING);
myAcc.setInterrupt(ADXL345_DATA_READY, INT_PIN_2);
myAcc.readAndClearInterrupts();
// TODO add calibration routine
int missed = 0;
Serial.println("Beginning capture.");
// Begin data acq
for(int cnt = 0; cnt < NUM_SAMPLES; cnt++) {
// Wait for new data
while(!dataReady) {}
dataReady = false;
samples[cnt] = myAcc.getGValues();
if (dataReady) {
// new data received before we were ready to process it => probable miss
missed ++;
Serial.println("Capture done.");
Serial.println("Removing DC");
processRemoveDC();
Serial.println("DATA_START");
Serial.println("X\tY\tZ");
Serial.printf("%f\t%f\t%f\n", samples[cnt].x,samples[cnt].y,samples[cnt].z);
Serial.println("DATA_END");
Serial.printf("%d Sample(s) missed\n", missed);
printRMS();
delay(5000);
/* Removes the continuous (dc) component
This will operate inplace and edit the acquired data !
void processRemoveDC() {
float meanX, meanY, meanZ = 0;
for (int cnt = 0; cnt < NUM_SAMPLES; cnt++) {
meanX += samples[cnt].x;
meanY += samples[cnt].y;
meanZ += samples[cnt].z;
meanX /= (float) NUM_SAMPLES;
meanY /= (float) NUM_SAMPLES;
meanZ /= (float) NUM_SAMPLES;
samples[cnt].x -= meanX;
samples[cnt].y -= meanY;
samples[cnt].z -= meanZ;
/ Computes and print the RMS per axis
void printRMS() {
float rmsX, rmsY, rmsZ = 0;
rmsX += pow(samples[cnt].x, 2);
rmsY += pow(samples[cnt].y, 2);
rmsZ += pow(samples[cnt].z, 2);
rmsX = sqrt(rmsX/(float)NUM_SAMPLES);
rmsY = sqrt(rmsY/(float)NUM_SAMPLES);
rmsZ = sqrt(rmsZ/(float)NUM_SAMPLES);
Serial.printf("RMS : X %f\tY %f\tZ %f\n", rmsX, rmsY, rmsZ);
void dataReadyISR(){
dataReady = true;
I've checked that I've selected the right serial port in the Arduino IDE and that the USB drivers for the ESP32 are correctly installed on my computer. I've also tried restarting my computer and updating the ESP32 package in the Arduino IDE, but the problem persists.
How can I resolve this error and successfully compile my program for ESP32?
Thanks in advance for your help!
here is the error:
WARNING: Category '' in library ESP Insights is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP RainMaker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFiProv is not valid. Setting to 'Uncategorized'
File "/home/ubuntu/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool.py", line 31, in <module>
import esptool
File "/home/ubuntu/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/__init__.py", line 41, in <module>
from esptool.cmds import (
File "/home/ubuntu/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/cmds.py", line 14, in <module>
from .bin_image import ELFFile, ImageSegment, LoadFirmwareImage
File "/home/ubuntu/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/bin_image.py", line 14, in <module>
from .loader import ESPLoader
File "/home/ubuntu/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/loader.py", line 30, in <module>
import serial
exit status 1
Error compiling for board ESP32 Dev Module.
Update with blink example:
* https://circuits4you.com
* ESP32 LED Blink Example
* Board ESP23 DEVKIT V1
* ON Board LED GPIO 2
#define LED 2
// Set pin mode
pinMode(LED,OUTPUT);
delay(500);
digitalWrite(LED,HIGH);
delay(500);
digitalWrite(LED,LOW);
Returns:
import esptool
import serial
exit status 1
