I'm trying to setup an installation of the IDE 2.3 in a Ubuntu 24.04 LTS (beta) environment, and am facing an issue I'm unable to resolve. The IDE gets to the GUI for accepting terms and conditions, and just crashes if I try to proceed.
What I tried from the internet The App Image complains about Chrome Sandbox. Someone has had this issue in the past, but in their case, they got a path for chrome-sandbox in /home/username/... so it was always the same, and they could chown it. I'm getting a random path in /tmp and it always vanishes after the App Image crashes.
Source: https://forum.arduino.cc/t/linux-install-issues/880034/4
CLI output
username@username-e14:/opt$ ./arduino-ide_2.3.2_Linux_64bit.AppImage
[14059:0413/233905.813890:FATAL:setuid_sandbox_host.cc(158)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /tmp/.mount_arduinGsNYxm/chrome-sandbox is owned by root and has mode 4755.
Trace/breakpoint trap (core dumped)
username@username-e14:/opt$ ll
total 185608
drwxr-xr-x  9 root  root              4096 Apr 13 23:32 ./
drwxr-xr-x 23 root  root              4096 Apr 12 10:14 ../
-rwxrwxr-x  1 username username  190013338 Apr 13 23:16 arduino-ide_2.3.2_Linux_64bit.AppImage*
drwxr-xr-x  8 root  root              4096 Apr 12 20:18 arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi/
drwxr-xr-x  3 root  root              4096 Apr 12 11:07 google/
drwx------  2 root  root             16384 Apr 12 10:15 lost+found/
drwxr-xr-x  5 root  root              4096 Apr 12 21:10 .pio-env/
drwxr-xr-x  3 root  root              4096 Apr 12 20:21 STMicroelectronics/
I've tried these ownership combinations for the App Image, and all three give the same issue:
$ sudo chown username:username arduino-ide_2.3.2_Linux_64bit.AppImage
$ sudo chown root:username arduino-ide_2.3.2_Linux_64bit.AppImage
$ sudo chown root:root arduino-ide_2.3.2_Linux_64bit.AppImage
How do I proceed?
You can run Arduino IDE by adding --no-sandbox in the command line when starting it.
This is a workaround for a real problem with Ubuntu Noble 24.04 beta. Also other appimage files, like the one for Cider, have the same issue and solution.
Greenonline
  • 3,152
  • 36
  • 48
BertRAMAerts
  • 131
