I'm using an ESP8266, ArduinoJson v6.21.5. PlatformIO, and Vscode.
The config file is saved and read correctly to the ESP8266's flash:
"gen_pubTopic": [
"DvirHome/Messages",
"DvirHome/log",
"DvirHome/debug"
"subTopic": [
"DvirHome/Light/int/KitchenLEDs",
"DvirHome/All",
"DvirHome/Light/int",
"DvirHome/Light"
"pubTopic": [
"DvirHome/Light/int/KitchenLEDs/Avail",
"DvirHome/Light/int/KitchenLEDs/State"
In case the config file is missing, t[], t2[], and t3[] are hard-coded to avoid boot failure.
There are 3 for loops to read topics (from the config file or from hard-coded).
The unexplained part is:
The config file is saved and read as expected, and the code runs without any failure.
when the
forloop containsDOC["gen_pubTopic"].size()topics are read as expected, but when it is defined asDOC["gen_pubTopic"].size() |3it crashes.x,x2, andx3are defined before eachforloop. Again, once as defined in 2), still no change.At some part it happened at the 3rd
forloop, and sometimes at the 2ndforloop.Printing
xivalues shows the expected values.To make it clear - without using "fallback annotation"
|2the code runs without crashing.In all stages above - the fallback stage is not tested (meaning- config file is saved and read), and crashes happens when "fallback annotation" is added.
Appreciate any lead why.
void start_iot2(JsonDocument &DOC)
/* Default values /
const char t[] = {"DvirHome/Messages", "DvirHome/log", "DvirHome/debug"};
const char t2[] = {"DvirHome/Device", "DvirHome/All"};
const char t3[] = {"DvirHome/Device/Avail", "DvirHome/Device/State"};
uint8_t x = DOC["gen_pubTopic"].size() | 3;
for (uint8_t i = 0; i < x; i++)
/* Some Code /
/ debug code */
Serial.print("Gen_");
Serial.println(i);
uint8_t x2 = DOC["subTopic"].size() | 2;
for (uint8_t i = 0; i < x2; i++)
/* Some Code /
/ debug code */
Serial.print("Sub_");
Serial.println(i);
uint8_t x3 = DOC["pubTopic"].size() | 2;
for (uint8_t i = 0; i < x3; i++)
/* Some Code /
/ debug code */
Serial.print("Pub_");
Serial.println(i);
iot.start_services(extMQTT);
Edit_1
Added /*debug Code */ to for loops.
At some point, the Serial Monitor showed:
Sub_0
Sub_1
Sub_2
Sub_3
Sub_4
Sub_5
while the size of the SubTopic array is 4 and |2 as default.
