I have this ESP8266 Heltec NodeMCU board with OLED. The pins are described here.
I have the following problem. The both OLED (with u8g2) and Wifi work fine individually. There is a problem getting them working together.
In particular, the following code works (and shows Hello World, blanks the screen and then repeats):
#include <U8g2lib.h>
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0, U8X8_PIN_NONE);
u8g2.begin();
u8g2.setFont(u8g2_font_ncenB14_tr);
u8g2.firstPage();
do {
u8g2.setCursor(0, 20);
u8g2.print(F("Hello World!"));
} while ( u8g2.nextPage() );
delay(2000);
u8g2.clear();
delay(2000);
Adding the Wifi to the code (the only difference to the code above are the 2 lines in the setup).
#include <ESP8266WiFi.h>
u8g2.begin();
WiFi.begin ( "xxx", "yyy" );
while ( WiFi.status() != WL_CONNECTED ) { delay(500); }
u8g2.firstPage();
do {
delay(2000);
u8g2.clear();
delay(2000);
In this case, "Hello World" appears 3 times and then the screen remains blank.
Edit:
I noticed something which, I believe, is an important piece of information when I turned the debugging of the WiFi on.
The display stops working after the output pm open,type:2 0 of the debugger. I believe that pm refers to powermanagement. Could it be that the system goes sleeping? How to prevent this from happening?
