I'm using Arduino IDE 2.1.1 on a Mac M2 and it's failing to upload, No drive to deploy, I have tried 3 different Mac's, and multiple Picos & USB cables.
Summary of what I've done:
  • Loaded Example Blink application
  • Selected board Raspberry Pico W from Raspberry Pi Pico Arduino core 3.3.2
  • Port selection initially UF2 which shows connected and successfully uploads, then shows as /dev/cu.usbmodem1101
The first time I do the above the blink application works but any further uploads to /dev/cu.usbmodem1101 fail, with the following output:
Resetting /dev/cu.usbmodem1101
Converting to uf2, output size: 660992, start address: 0x2000
Scanning for RP2040 devices
No drive to deploy.
Failed uploading: uploading error: exit status 1
I have only two ports available for upload
  • /dev/cu.Bluetooth-Incoming-Port
  • /dev/cu.usbmodem1101
It feels as if I'm either consistently missing some key configuration details or there's technical issues with Arduino IDE or the Pico's
dankeboy36
  • 94
Duncan Hill
  • 111
