I need debouncing/stateChange for a push button configuration. Is there a good library for debouncing/stateChange buttons in Arduino (without delay)?
dda
  • 1,595
Ariyan
  • 181
7 Answers7
The Button library in the Arduino playground works perfectly.
Twim
  • 81
I think what you need is an interrupt-based detection of the button. This way, your Arduino can do what it needs to do without stalling for the delay function.
// Example code usage
int pin = 13; // LED on board
int interrupt0pin = 2; // pin attached to int0 if you're using Uno
int buttonState;
void setup()
  pinMode(pin, OUTPUT);
  pinMode(interrupt0pin, INPUT);
  attachInterrupt(0, buttonUpdate, CHANGE); // calls buttonUpdate() when button input changes (you can also use high-to-low or low-to-high)
void loop()
    if (buttonState)
        digitalWrite(pin, HIGH);
    else
        digitalWrite(pin, LOW);
void buttonUpdate()
  buttonState = digitalRead(interrupt0pin);
  delay(50); // 50ms works for most switches - adjustable
Find out more here: http://arduino.cc/en/Reference/AttachInterrupt
Good luck!
bot3663369
  • 271
I'm on this subject right now and I'll use this to note my findings.
I found many libs on this, and this is my wishlist:
  • support many buttons
  • support toggles or switches
  • support debouncing and maybe de-glitching
  • non-blocking functions
  • support long-press, double-click
Candidates:
Here are my findings for each lib:
Switch
  • it's really easy to use
  • you can use it as a switch or a button, same class handles both
  • supports callbacks
  • supports many buttons
  • supports debouncing and de-glitching
  • supports double click and long press
  • most configs have defaults, and you define them at the Button setup
  • as I use PlatformIO, some warnings from this lib are shown while compiling my project
EasyButton
  • very good docs
  • does not support toggles/switches, although you can simulate it by checking the wasPressed and wasReleased properties
  • supports double click, triple click, or a given number of clicks
  • you may have a different action for single, double or triple click for the same button
  • supports multiple times of long press, if needed
JC Button
  • easy to use, not as easy as Switch and EasyButton tough
  • you can use it as a Button or a switch (ToggleButton), different class for each
  • does not support callbacks
  • most configs have defaults, and you may define them at the Button setup, but long press time is something you define while querying it's status rather than defining it once at the button setup
ezButton
  • does not support toggles/switches, although you can simulate it by checking the isPressed and isReleased events
  • does not support long press
  • supports debouncing, does not debounce by default (you must call setDebounceTime on setup)
  • supports an easy way to count button clicks
Veredict
I chose avdweb/Switch. Reasons:
  • in terms of debouncing AND de-glitching, it did better according to my tests
  • I need a solution for Buttons and Switches, and it provides them in the same class
Feu
  • 131
You can use my library
https://github.com/anlgncr/Buttons
This library lets you use buttons as many as you wish with only one instance of class.
You can also call a function when button is pushed or released.
Greenonline
  • 3,152
  • 36
  • 48
gencer
I put this together for a guy the other day. Its not a library but it achieves reading and debouncing all of your buttons and works very well maybe it could help you
const byte numbuttons = 15;                                                     // DEFINE HOW MAY DIGITAL INPUTS TO MONITOR(NUMBER OF BELOW PINS TO USE)
const byte digitalpin[] = { 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 14, 15, 16 };   // DECLARE ALL DIGITAL INPUT PINS WHICH CAN BE USED IN THE ORDER IN WHICH THEY WILL BE PHYSICALLY USED(DONT INCLUDE ANY PINS USED FOR OTHER THINGS
const byte debouncetime = 50;                                                   // THIS VALUE IS THE TIME TO WAIT BEFORE RECHECKING (FOR DEBOUNCE
byte readstate[numbuttons];                                                     // READ ARRAY
byte laststate[numbuttons];                                                     // HOLDS THE BUTTON LAST STATE FOR STATE CHANGE DETECTION
byte NumBut;        // THIS IS THE VARIABLE FOR DIGITAL FORLOOP COUNTER
unsigned long checktime;                                            // RECORDS THE TIMES (IN MILLIS() TO RECHECK THE STATE FOR EACH BUTTON. FOR DEBOUCING
byte CURRENT_SETTING;
  // SET INITIAL STATES FOR DIGITALS
  for (NumBut = 0; NumBut < numbuttons; NumBut++) {
    pinMode(digitalpin[NumBut], INPUT_PULLUP);
    laststate[NumBut] = digitalRead (digitalpin[NumBut]);
    checktime = 0;
  //call the read button method
  READBUTTONS();
  PROGRAM_OUTPUT();
void READBUTTONS() {
    readstate[NumBut] = (digitalRead (digitalpin[NumBut]));        // READ DIGITAL INPUTS INTO ARRAY
    if (readstate[NumBut] != laststate[NumBut] && millis() >= checktime )   {
      if (readstate[NumBut] == 0 && laststate[NumBut] == 1) {
        checktime = millis() + debouncetime;
        CURRENT_SETTING = NumBut;
      laststate[NumBut] = readstate[NumBut];
void PROGRAM_OUTPUT(){
    switch ( CURRENT_SETTING ) {
    case 0:   //do something to turn off output break;
    case 1:   //do something with setting 1 break;
    case 2:   //do something with setting 2 break;
    case 3:   //do something with setting 3 break;
    default:    break;
R Lloyd
  • 33
I can receommend the following library:
http://log.liminastudio.com/itp/physical-computing/arduino-a-new-improved-button-library-with-some-handy-features https://github.com/virgildisgr4ce/Button
On the website you will find some examples on how to use it. I have implemented this library already in several sketches and it works very reliably.
hobie
  • 487
You can put a capacitor in parallel with the switch - 100nf should do the trick. Some capacitors have a minus on the packaging, next to one of the pins - if so, make sure that side is to negative (ground).
AMADANON Inc.
  • 2,383
