I'm getting the error as follows
Sketch uses 2952 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 196 bytes (9%) of dynamic memory, leaving 1852 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM5": Access is denied.
Failed uploading: uploading error: exit status 1
The board I am using is Arduino Uno and checked the ports too. Also restarted and installed IDE again. But still not being able to deal with it. I will be happy with the help!
Rohit Gupta
  • 618
Neha Malode
In Windows (if you are using windows), There are two things may caused the problem:
  • go to device manager >> ports >> and Uninstall all ports related to Arduino (including the COM5). Then connect the arduino again and it install it again automatically.
  • Make sure that you close all "serial monitor", before uploading the sketch.
Jon depoy
  • 61
