I have the following situation. When I power my DHT22 with the 3.3V from the Arduino UNO (and Ground it there), then I can read the data perfectly fine using the DHT library from Adafruit.
However, when I connect the DHT22 to my own external power supply (and respective ground), it fails. The reason for using this external power supply is so I can hook it up to a ESP8266 later.
The power supply I build uses a 5V adapter, then an LD33V converter and (just for experimentation) an 100nF capacitor to reduce any noise on the line. I measured this external power supply and it indeed gives off 3.3V after the LD33V. I check the datasheet of the LD33V and it should be able to 'give' 5mA, whereas the DHT22 needs less than 1mA for operation.
I don't know where to look at this moment. Can someone point me in the right direction? Much appreciated :)
Cheers
zwep
  • 119
Have you connected the external power supply ground to the Arduino's ground? If not, one is "floating" with respect to the other. But they need to have the same reference - the ground sides of their power supplies.
JRobert
  • 15,407
