The idea was to create a bluetooth device on the arduino to read data from the machine (ELM327 v2.1) using the HC-05 bluetooth module.
In this code the bluetooth module is switched to MASTER mode and connected to ELM327 using its MAC address. The responses of the module in the code are in the comments.
#include <SoftwareSerial.h>
SoftwareSerial bluetoothSerial(4, 5);
Serial.begin(9600);
Serial.print("READY");
bluetoothSerial.begin(38400);
delay(1000);
getSetAtCommand("AT"); //OK
getSetAtCommand("AT+CMODE=0"); //OK
getSetAtCommand("AT+PSWD=1234"); //OK
getSetAtCommand("AT+ROLE=1"); //OK
getSetAtCommand("AT+BIND=0010,CC,4F3603"); //OK
getSetAtCommand("AT+LINK=0010,CC,4F3603"); //OK
delay(1000);
getSetAtCommand("AT+STATE?"); // OK: CONNECTED
delay(1000);
getSetAtCommand("ATZ"); //no answer, the buffer is empty
getSetAtCommand("AT015B");//no answer, the buffer is empty
getSetAtCommand("015B"); //no answer, the buffer is empty
getSetAtCommand("ATRV"); //no answer, the buffer is empty
getSetAtCommand("0105"); //no answer, the buffer is empty
getSetAtCommand("at i"); //no answer, the buffer is empty
getSetAtCommand("at rv"); //no answer, the buffer is empty
getSetAtCommand("ati"); //no answer, the buffer is empty
getSetAtCommand("atrv"); //no answer, the buffer is empty
void getSetAtCommand(String command) {
Serial.println(command);
String added_command = command + "\r\n";
bluetoothSerial.print(added_command);
delay(500);
while (bluetoothSerial.available()) {
Serial.write(bluetoothSerial.read());
Since the State returns CONNECTED, I assume that it is connected to the ELM.
To the command AT+PAIR=0010,CC,4F3603,20\r\n the module does not respond. The module also does not respond to commands such as ATZ\r\n, AT015B\r\n, 015B\r\n, ATRV\r\n, 0105\r\n, at i\r\n, at rv\r\n, ati\r\n, atrv\r\n. Sometimes the answer is ERROR[0], as I understand it means that there is no such command.
It seems to me that these commands don't reach the ELM at all. What can be the problem?
The ELM327 itself works, connects to the phone without any problems and shows the data.
Tried through the simulator on a laptop, the connected bluetooth model is displayed in the bluetooth devices on the laptop and also does not work as with the ELM.
