I'm trying to connect a ESP32 client using SocketIO with a Flask-SocketIO server and it's not getting connected.
The server uses SSL. The local server address is https://192.168.1.137:3000.Is the https causing issue here?
The following is the output from the ESP32 in the serial monitor. Note that esp32 successfully connects to the wifi.
> ["myEvent",{"now":95506}]
> [IOc] Disconnected!
> [IOc] Disconnected!
> [IOc] Disconnected!
Esp32 code:
* WebSocketClientSocketIOack.ino
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>
#include <WebSocketsClient.h>
#include <SocketIOclient.h>
WiFiMulti WiFiMulti;
SocketIOclient socketIO;
#define USE_SERIAL Serial
void socketIOEvent(socketIOmessageType_t type, uint8_t * payload, size_t length) {
switch(type) {
case sIOtype_DISCONNECT:
USE_SERIAL.printf("[IOc] Disconnected!\n");
break;
case sIOtype_CONNECT:
USE_SERIAL.printf("[IOc] Connected to url: %s\n", payload);
// join default namespace (no auto join in Socket.IO V3)
socketIO.send(sIOtype_CONNECT, "/");
break;
case sIOtype_EVENT:
char * sptr = NULL;
int id = strtol((char *)payload, &sptr, 10);
USE_SERIAL.printf("[IOc] get event: %s id: %d\n", payload, id);
if(id) {
payload = (uint8_t *)sptr;
DynamicJsonDocument doc(1024);
DeserializationError error = deserializeJson(doc, payload, length);
if(error) {
USE_SERIAL.print(F("deserializeJson() failed: "));
USE_SERIAL.println(error.c_str());
return;
String eventName = doc[0];
USE_SERIAL.printf("[IOc] event name: %s\n", eventName.c_str());
// Message Includes a ID for a ACK (callback)
if(id) {
// creat JSON message for Socket.IO (ack)
DynamicJsonDocument docOut(1024);
JsonArray array = docOut.to<JsonArray>();
// add payload (parameters) for the ack (callback function)
JsonObject param1 = array.createNestedObject();
param1["now"] = millis();
// JSON to String (serializion)
String output;
output += id;
serializeJson(docOut, output);
// Send event
socketIO.send(sIOtype_ACK, output);
break;
case sIOtype_ACK:
USE_SERIAL.printf("[IOc] get ack: %u\n", length);
break;
case sIOtype_ERROR:
USE_SERIAL.printf("[IOc] get error: %u\n", length);
break;
case sIOtype_BINARY_EVENT:
USE_SERIAL.printf("[IOc] get binary: %u\n", length);
break;
case sIOtype_BINARY_ACK:
USE_SERIAL.printf("[IOc] get binary ack: %u\n", length);
break;
//USE_SERIAL.begin(921600);
USE_SERIAL.begin(115200);
//Serial.setDebugOutput(true);
USE_SERIAL.setDebugOutput(true);
// USE_SERIAL.println();
// for(uint8_t t = 4; t > 0; t--) {
// USE_SERIAL.printf("[SETUP] BOOT WAIT %d...\n", t);
// USE_SERIAL.flush();
// delay(1000);
WiFiMulti.addAP("ssid", "mypass");
//WiFi.disconnect();
while(WiFiMulti.run() != WL_CONNECTED) {
delay(100);
String ip = WiFi.localIP().toString();
USE_SERIAL.printf("[SETUP] WiFi Connected %s\n", ip.c_str());
// server address, port and URL
socketIO.begin("192.168.1.137", 3000, "/socket.io/?EIO=4");
// event handler
socketIO.onEvent(socketIOEvent);
unsigned long messageTimestamp = 0;
socketIO.loop();
uint64_t now = millis();
if(now - messageTimestamp > 2000) {
messageTimestamp = now;
// creat JSON message for Socket.IO (event)
JsonArray array = doc.to<JsonArray>();
// add event name
// Hint: socket.on('event_name', ....
array.add("myEvent");
// add payload (parameters) for the event
param1["now"] = (uint32_t) now;
String output;
serializeJson(doc, output);
// Send event
socketIO.sendEVENT(output);
// Print JSON for debugging
USE_SERIAL.println(output);
Server code (Removed unrelated parts):
from flask import Flask, render_template, Blueprint, current_app, request, session, url_for, render_template
from flask_socketio import SocketIO, emit
from threading import Thread
from queue import Queue
import logging
loggerPath = baseUrl + "logs/appLog.log"
os.makedirs(os.path.dirname(loggerPath), exist_ok=True)
with open(loggerPath, "a") as f:
logging.basicConfig( level=logging.INFO,
# format='%(asctime)s - %(name)s - %(levelname)s - %(message)s',
format='%(levelname)s - %(message)s',
filename=loggerPath
bp = Blueprint('audio', name, static_folder='static',
template_folder='templates')
app = Flask(name)
async_mode = "threading"
socketio = SocketIO(app, cors_allowed_origins="*", async_mode=async_mode)
@socketio.on('myEvent')
def test_connect(data):
logging.info("receiving")
def runApp():
try:
certificatePath = os.getenv('BASE_URL')+"SSL/"
key = certificatePath+"localhost.key"
certificate = certificatePath+"localhost.crt"
context = ssl.SSLContext(ssl.PROTOCOL_TLS_SERVER)
context.load_cert_chain(certificate, key)
ip = socket.gethostbyname(socket.gethostname())
socketio.run(app, host=ip, port=3000,ssl_context=context)
except Exception as e:
logging.error("Exception occurred in: "+file, exc_info=True)
q = Queue()
t = Thread(target=wrapper, args=(q, runApp), daemon=True)
t.start()
