I am currently controlling two servos using the Arduino IDE, but now need to integrate my Arduino code into a Python script. I read about how to use PyFirmata and went through the process of uploading StandardFirmata to my Arduino Mega 2560 board after changing the samplingInterval value to 99, instead of the default 19. However, having followed the exact procedure of translating Arduino code to Python and downloading/using the correct pyfirmata package, the board simply does not react. I tested the board, the individual servos, power, etc. and have even used the ArduinoMega module in pyfirmata, but there is absolutely no reaction when using the Python code. I have looked through multiple online forums and it seems that this is a recurring issue, but no one has posted a solution (as per my knowledge) to the problem and it would be of great help if someone could help me fix this. Please let me know if you would like to see any of the code, it is very simple and I do not mind sharing it if required. Thanks in advance!
Asked
Active
Viewed 232 times
Before uploading StandardFirmata to Arduino check baud rate in StandardFirmata sketch at line Firmata.begin()
BettyK
- 1
