I am trying to use a Waveshare 4.2inch e-paper display with an Adafruit Feather Adalogger M0, but am having issues with two separate instances of #define GET_STATUS being defined differently in different locations. More specifically, in the Demo Library (download) for the Waveshare display, one of the files (epd4in2.h) defines GET_STATUS as 0x71. However, in a file (USBCore.h) I downloaded from the board manager in the ArduinoIDE to be able to support the Feather Adalogger, GET_STATUS is defined as 0.
I've tried messing with the values to see if making them match (both as 0x71 and both as 0) would solve the issue, but it didn't change anything. I can't find any information about what GET_STATUS in general, so I'm unsure what I can even try to fix this issue. Furthermore, I can't find any instances of GET_STATUS being used, so I'm unsure what its significance even is. So, basically, my questions are: 1) what is the significance of GET_STATUS, and 2) how can I reconcile it being used differently in two different places?
Below is the code I'm trying to run (it's the demo code from Waveshare), and the libraries other than "<SPI.h>" are in the demo library download from Waveshare.
#include <SPI.h>
#include "epd4in2.h"
#include "imagedata.h"
#include "epdpaint.h"
#define COLORED 0
#define UNCOLORED 1
Serial.begin(9600);
Epd epd;
if (epd.Init() != 0) {
Serial.print("e-Paper init failed");
return;
/* This clears the SRAM of the e-paper display */
epd.ClearFrame();
* Due to RAM not enough in Arduino UNO, a frame buffer is not allowed.
* In this case, a smaller image buffer is allocated and you have to
* update a partial display several times.
* 1 byte = 8 pixels, therefore you have to set 8N pixels at a time.
unsigned char image[1500];
Paint paint(image, 400, 28); //width should be the multiple of 8
paint.Clear(UNCOLORED);
paint.DrawStringAt(0, 0, "e-Paper Demo", &Font24, COLORED);
epd.SetPartialWindow(paint.GetImage(), 100, 40, paint.GetWidth(), paint.GetHeight());
paint.Clear(COLORED);
paint.DrawStringAt(100, 2, "Hello world", &Font24, UNCOLORED);
epd.SetPartialWindow(paint.GetImage(), 0, 64, paint.GetWidth(), paint.GetHeight());
paint.SetWidth(64);
paint.SetHeight(64);
paint.DrawRectangle(0, 0, 40, 50, COLORED);
paint.DrawLine(0, 0, 40, 50, COLORED);
paint.DrawLine(40, 0, 0, 50, COLORED);
epd.SetPartialWindow(paint.GetImage(), 72, 120, paint.GetWidth(), paint.GetHeight());
paint.DrawCircle(32, 32, 30, COLORED);
epd.SetPartialWindow(paint.GetImage(), 200, 120, paint.GetWidth(), paint.GetHeight());
paint.DrawFilledRectangle(0, 0, 40, 50, COLORED);
epd.SetPartialWindow(paint.GetImage(), 72, 200, paint.GetWidth(), paint.GetHeight());
paint.DrawFilledCircle(32, 32, 30, COLORED);
epd.SetPartialWindow(paint.GetImage(), 200, 200, paint.GetWidth(), paint.GetHeight());
/* This displays the data from the SRAM in e-Paper module */
epd.DisplayFrame();
/* This displays an image */
epd.DisplayFrame(IMAGE_BUTTERFLY);
/* Deep sleep */
epd.Sleep();
// put your main code here, to run repeatedly:
When I run the code, I get the following messages
In file included from /home/beingpool/Arduino/epd4in2-demo/epd4in2-demo.ino:28:
/home/<user>/Arduino/libraries/epd4in2/epd4in2.h:64: warning: "GET_STATUS" redefined
64 | #define GET_STATUS 0x71
In file included from /home/beingpool/.arduino15/packages/adafruit/hardware/samd/1.7.11/cores/arduino/Arduino.h:157,
from /home/beingpool/.var/app/cc.arduino.IDE2/cache/arduino/sketches/96EFEDEA56FF573B678089A960FFC685/sketch/epd4in2-demo.ino.cpp:1:
/home/beingpool/.arduino15/packages/adafruit/hardware/samd/1.7.11/cores/arduino/USB/USBCore.h:23: note: this is the location of the previous definition
23 | #define GET_STATUS 0
