When running two threads, one for blinking led once every second, one for sweeping the servo 180 degrees. The servo just vibrates.
When I tested adding a serial printout in the run servo for loops for the pos variable it worked but a bit jerky. Any idea what could be the problem?
#include <Arduino.h>
#include <pt.h>
#include <Servo.h>
// put function declarations here: static struct pt pt1; static struct pt pt2; Servo myservo; int pos = 0;
static int protothreadBlinkLED(struct pt *pt) { static unsigned long lastTimeBlink = 0; PT_BEGIN(pt); while(1) { lastTimeBlink = millis(); PT_WAIT_UNTIL(pt, millis() - lastTimeBlink > 1000); digitalWrite(LED_BUILTIN, HIGH); lastTimeBlink = millis(); PT_WAIT_UNTIL(pt, millis() - lastTimeBlink > 1000); digitalWrite(LED_BUILTIN, LOW); } PT_END(pt); }
static int protoThreadRunServo(struct pt *pt) { static unsigned long lastServoUpdate = 0; PT_BEGIN(pt); while(1) { lastServoUpdate = millis(); for(pos = 0; pos < 180; pos += 1) { PT_WAIT_UNTIL(pt, millis() - lastServoUpdate > 150); myservo.write(pos);
} for(pos = 180; pos >= 1; pos -= 1) {
PT_WAIT_UNTIL(pt, millis() - lastServoUpdate > 150); myservo.write(pos); } } PT_END(pt); }
void setup() { // put your setup code here, to run once: pinMode(LED_BUILTIN, OUTPUT); myservo.attach(9); PT_INIT(&pt1); PT_INIT(&pt2); }
void loop() { // put your main code here, to run repeatedly: protothreadBlinkLED(&pt1); protoThreadRunServo(&pt2); }
jst_swe
