I have a ESP32-CAM AIThinker which I have programmed using Arduino IDE to stream video. I have another board ESP8266-12e that I am using on a MQTT system that turns on and off the ESP32 as well as sending it the Name and password of my local network to sign in. When the ESP32-CAM is on and streaming I can access it on my local network and by port forwarding in my Router I can sign in and view it from anywhere. I have built a Mac and Android app which will access and stream the ESP32 displaying it inside the app.
I would rather NOT port forward my router. Is there a way to add some code to the ESP32 so that I could use Apple TV, or the Android equivalent, or HomeKit, to open the port associated with the ESP32 so it can be accessed outside my local network? Port forward is not real secure and I would like to avoid it if possible.
I have added some code to try to POST the jpg-stream to my WIX website where I added a page with an image. However even though the website got the POST and it was valid I received a response code 403 FORBIDDEN this is the full response.
10:25:03.026 -> 403
10:25:03.026 -> <html>
10:25:03.026 -> <head><title>403 Forbidden</title></head>
10:25:03.026 -> <body>
10:25:03.026 -> <center><h1>403 Forbidden</h1></center>
10:25:03.026 -> <hr><center>nginx</center>
10:25:03.026 -> </body>
10:25:03.026 -> </html>
Here is the code currently running on the ESP32-CAM;
#include "src/OV2640.h"
#include <WiFi.h>
#include <WebServer.h>
#include <time.h>
#include "FS.h" // SD Card ESP32
#include "SD_MMC.h" // SD Card ESP32
#include <WiFiClient.h>
#include <EEPROM.h>
#include <string.h>
#include <stdio.h>
//ADDED FOR POST
#include <HTTPClient.h>
int know;
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
//for reconnect
unsigned long previousMillis = 0;
unsigned long interval = 30000;
//stuff to bring in string
const byte numChars = 100;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
// variables to hold the parsed data
char messageFromPC[numChars] = {0};
float floatFromPC = 0;
char ssidString[numChars] = {0};
float floatFromPC2 = 0;
char pskString[numChars] = {0};
char IP[numChars] = {0};
char zone[numChars] = {0};
char myChar[numChars]= {0};
char myChar2[numChars]= {0};
char myChar3[numChars]= {0};
char myChar4[numChars]= {0};
boolean newData = false;
//end stuff ti bring in string
String f;
int addr = 0;
OV2640 cam;
WebServer server(XX);
const char HEADER[] = "HTTP/1.1 200 OK\r\n"
"Access-Control-Allow-Origin: *\r\n"
"Content-Type: multipart/x-mixed-replace; boundary=123456789000000000000987654321\r\n";
const char BOUNDARY[] = "\r\n--123456789000000000000987654321\r\n";
const char CTNTTYPE[] = "Content-Type: image/jpeg\r\nContent-Length: ";
const int hdrLen = strlen(HEADER);
const int bdrLen = strlen(BOUNDARY);
const int cntLen = strlen(CTNTTYPE);
void handle_jpg_stream(void)
char buf[32];
int s;
WiFiClient client = server.client();
client.write(HEADER, hdrLen);
client.write(BOUNDARY, bdrLen);
while (true)
if (!client.connected()) break;
cam.run();
s = cam.getSize();
client.write(CTNTTYPE, cntLen);
sprintf( buf, "%d\r\n\r\n", s );
client.write(buf, strlen(buf));
client.write((char *)cam.getfb(), s);
const char JHEADER[] = "HTTP/1.1 200 OK\r\n"
"Content-disposition: inline; filename=capture.jpg\r\n"
"Content-type: image/jpeg\r\n\r\n";
const int jhdLen = strlen(JHEADER);
void handle_jpg(void)
cam.run();
if (!client.connected()) return;
client.write(JHEADER, jhdLen);
client.write((char *)cam.getfb(), cam.getSize());
void handleNotFound()
String message = "Server is running!\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
server.send(200, "text / plain", message);
void setup()
Serial.begin(57600);
Serial.print("setup");
delay(10000);
//RESET EEPROM COMMENT OUT
if(Serial.available()){
delay(2000);
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
parseData();
showParsedData();
newData = false;
//TO HERE
delay(10000);
Serial.print("network");
Serial.print(ssidString);
Serial.print("pass");
Serial.print(pskString);
Serial.print("time zone");
Serial.print(zone);
if(ssidString[0] != '\0'){
EEPROM.begin(512); //Initialize EEPROM
// write appropriate byte of the EEPROM.
// these values will remain there when the board is
// turned off.
EEPROM.write(addr, 'A'); //Write character A
addr++; //Increment address
EEPROM.write(addr, 'B'); //Write character B
EEPROM.write(addr, 'C'); //Write character C
//Write string to eeprom
//RESET EEPROM SWITCH THESE TWO
String www = ssidString +String(",") + String(pskString) + String(",")+String(zone)+String(",");
//String www = newString +String(",") + String(oldString) + String(",")+String(zoneString)+String(",");
Serial.print (www);
for(int i=0;i<www.length();i++) //loop upto string lenght www.length() returns length of string
EEPROM.write(0x0F+i,www[i]); //Write one by one with starting address of 0x0F
EEPROM.commit();
//Read string from eeprom //Increment address
//COMMENT OUT NEXT BRACKET RESET EEPROM
//RESET EEPROM COMMENT OUT NEXT SECTION
else if(ssidString[0] == '\0'){
EEPROM.begin(512);
Serial.println("WHAT"); //Goto next line, as ESP sends some garbage when you reset it
Serial.print(char(EEPROM.read(addr))); //Read from address 0x00
Serial.print(char(EEPROM.read(addr))); //Read from address 0x01
Serial.print(char(EEPROM.read(addr))); //Read from address 0x02
Serial.print(char(EEPROM.read(addr))); //Read from address 0x03
String www;
//Here we dont know how many bytes to read it is better practice to use some terminating character
//Lets do it manually www.circuits4you.com total length is 20 characters
for(int i=0;i<100;i++)
www = www + char(EEPROM.read(0x0F+i)); //Read one by one with starting address of 0x0F
Serial.println("this");
Serial.print(www); //Print the text on serial monitor
www.toCharArray(myChar,100);
char * token = strtok(myChar,",");
char * token2 = strtok(NULL,",");
char * token3 = strtok(NULL,",");
Serial.println("one");
Serial.print(token);
Serial.println("two");
Serial.print(token2);
Serial.println("three");
Serial.print(token3);
strcpy(myChar2,token);
strcpy(myChar3,token2);
strcpy(myChar4,token3);
//RESET EEPROM COMMENT OUT TO HERE
#define SSID1 ssidString
#define PWD1 pskString
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
// Frame parameters
// config.frame_size = FRAMESIZE_UXGA;
config.frame_size = FRAMESIZE_VGA;
config.jpeg_quality = 12;
config.fb_count = 2;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
cam.init(config);
IPAddress ip;
WiFi.mode(WIFI_STA);
// digitalWrite(33,LOW);
WiFi.begin(ssidString, pskString);
Serial.println("zone");
Serial.print(zone);
know = atoi(zone);
WiFi.begin(myChar2, myChar3);
Serial.println("myChar4");
know = atoi(myChar4);
Serial.print(myChar4);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(F("."));
String rrr = String("/") + String(zone) + String("/") + String ("1");
Serial.print("rrr");
Serial.println(rrr);
ip = WiFi.localIP();
Serial.println(F("WiFi connected"));
Serial.println("");
Serial.println(ip);
Serial.print("Stream Link: http://");
Serial.print(ip);
Serial.println(rrr);//userName
server.on(String(rrr), HTTP_GET, handle_jpg_stream);
server.on("/jpg", HTTP_GET, handle_jpg);
server.onNotFound(handleNotFound);
server.begin();
Serial.print("loop");
delay(1000);
void loop()
if (WiFi.status() == WL_DISCONNECTED){
Serial.print(zone);
know = atoi(zone);
delay(500);
unsigned long currentMillis = millis();
if((WiFi.status()!= WL_CONNECTED) & (currentMillis-previousMillis >= interval)){
Serial.print(millis());
WiFi.disconnect();
WiFi.reconnect();
previousMillis = currentMillis;
else if (WiFi.status() == WL_CONNECTED){
//THIS IS THE CODE I ADDED TRYING TO POST VIDEO
HTTPClient http;
http.begin ("https://www.creatucate.com/video-1");
http.addHeader("Content-Type","image/jpeg");
int httpResponseCode = http.POST("POSTING from ESP32");
if(httpResponseCode>0){
String response = http.getString();
Serial.println(httpResponseCode);
Serial.println(response);
else{
Serial.print("Error on sending POST: ");
//END NEW CODE
server.handleClient();
//more new stuff for string
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
//RESET EEPROM COMMENT OUT ALL THE REST
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,","); // get the first part - the string
strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
strcpy(ssidString,strtokIndx);
strcpy(pskString,strtokIndx);
strcpy(zone,strtokIndx);
void showParsedData() {
Serial.print("Message ");
Serial.println(messageFromPC);
Serial.print("water level ");
Serial.println(floatFromPC);
Serial.println(ssidString);
Serial.print("battery level ");
Serial.println(floatFromPC2);
Serial.println(pskString);
Serial.print("time zone is ");
Serial.println(zone);
If this is not the correct place for this question please advise me. I am not even sure this can be done but I hope so.
