I wrote simple program to test debug macros, but it gives me compilation error
Program:
#include <Arduino.h>
#define DEBUG
#ifdef DEBUG #define DPRINT(...) Serial.print(VA_ARGS) #define DPRINTLN(...) Serial.println(VA_ARGS) #else // define blank line #define DPRINT(...) #define DPRINTLN(...) #endif
void setup() { // put your setup code here, to run once: String str ="Hello MrNams"; DPRINT("Here is my string %s",str); }
void loop() { // put your main code here, to run repeatedly: }
Compilation Error:
src/main.cpp: In function 'void setup()': src/main.cpp:7:50: error: no matching function for call to 'HardwareSerial::print(const char [21], String&)' #define DPRINT(...) Serial.print(VA_ARGS) ^ src/main.cpp:19:3: note: in expansion of macro 'DPRINT' DPRINT("Here is my string %s",str); ^~~~~~ In file included from C:/Users//.platformio/packages/framework-arduinoespressif32/cores/esp32/Stream.h:26, from C:/Users//.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:177, from src/main.cpp:2: C:/Users//.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:81:12: note: candidate: 'size_t Print::print(const __FlashStringHelper*)' size_t print(const __FlashStringHelper *); ^~~~~ C:/Users//.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:81:12: note: candidate expects 1 argument, 2 provided
C:/Users//.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:82:12: note: candidate: 'size_t Print::print(const String&)'
size_t print(const String &);
MrNams
  • 129
