I've built the attached circuit with the following changes:
- I used Arduino Nano.
- I used 10K pot.
- 12V is connected to VIN pin (instead of RAW).
- The Arduino was connected to the PC by USB for the use of serial communication.
I used 12V 4Pin fan (C25704-002).
Here is the code, I used:
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
// Configure Timer 1 for PWM @ 25 kHz.
TCCR1A = 0; // undo the configuration done by...
TCCR1B = 0; // ...the Arduino core library
TCNT1 = 0; // reset timer
TCCR1A = _BV(COM1A1) // non-inverted PWM on ch. A
| _BV(COM1B1) // same on ch; B
| _BV(WGM11); // mode 10: ph. correct PWM, TOP = ICR1
TCCR1B = _BV(WGM13) // ditto
| _BV(CS10); // prescaler = 1
ICR1 = 320; // TOP = 320
// Set the PWM pins as output.
pinMode( 10, OUTPUT);
// PWM output @ 25 kHz, only on pins 9 and 10.
// Output value should be between 0 and 320, inclusive.
void analogWrite25k(int value)
OCR1A = value;
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
outputValue = map(sensorValue, 0, 1023, 0, 320);
analogWrite25k(outputValue);
I have the following questions:
- The circuit was working for couple of minutes but then I smelled the famous electronic components barbecue smell, so I disconnected the GND power line and when I did I felt that the GND line was hot, I think I fried the Arduino, Do you have an idea what can fry the Arduino?
- The Potentiometer (10K) was not sensitive, It worked only on some range of the knob, What resistance should I use?
Thanks.
