I have a potentiometer connected to an ADC input of an Arduino Leonardo. The ADC resolution is 10-bit (0..1024), while I need just 7-bit (0..127).
I use a simple filter to reduce the noise and then a map to cut the unused bits:
#define ADC_CH 18
#define ADC_FILTER 0.90
uint16_t value;
uint16_t adc = analogRead(ADC_CH);
value = (uint16_t) ((float) ADC_FILTER * adc + (1. - ADC_FILTER) * value);
I show value on an LCD. It's very stable, but it may happen that if the adc readings are in the nearby of two values, there is nothing that could prevent a change in the final value, even if the noise is of just few LSBs.
Is there a simple way to implement an hysteresis for each low-res value?
In this way the change between N and N+1 happens on a different ADC reading than between N and N-1, improving the noise rejection without increasing the filter delay (that would only increase the change interval).
