I'm following the standard process to put an STM32 "black pill" (STM32F401CC) into DFU mode so that I can upload from the Arduino IDE over USB:
- Hold down boot0.
- Press and release rst.
- Release boot0.
When the board is not in a circuit this works somewhat reliably but not 100%. While breadboarding with only a few connections it becomes very unreliable and sometimes won't work at all.
The USB serial device set up by my Arduino sketch works fine, it is only DFU mode that does not want to work.
When it fails to enter DFU mode I see the following error in the Arduino upload process:
STM32CubeProgrammer v2.13.0
An error occurred while uploading the sketch
Error: Target device not found
Establishing connection with the device failed
I'm using Arduino on Ubuntu 20.04 and when it fails I see in /var/log/syslog:
Apr 27 13:26:08 smurfenaar kernel: [79594.279257] usb 1-3: USB disconnect, device number 10
Apr 27 13:26:08 smurfenaar kernel: [79595.078232] usb 1-3: new full-speed USB device number 11 using xhci_hcd
Apr 27 13:26:09 smurfenaar kernel: [79595.192387] usb 1-3: device descriptor read/64, error -71
Apr 27 13:26:09 smurfenaar kernel: [79595.413389] usb 1-3: device descriptor read/64, error -71
Apr 27 13:26:09 smurfenaar kernel: [79595.636370] usb 1-3: new full-speed USB device number 12 using xhci_hcd
Apr 27 13:26:09 smurfenaar kernel: [79595.751435] usb 1-3: device descriptor read/64, error -71
Apr 27 13:26:09 smurfenaar kernel: [79595.973367] usb 1-3: device descriptor read/64, error -71
Apr 27 13:26:09 smurfenaar kernel: [79596.082540] usb usb1-port3: attempt power cycle
Apr 27 13:26:10 smurfenaar kernel: [79596.462407] usb 1-3: new full-speed USB device number 13 using xhci_hcd
Apr 27 13:26:10 smurfenaar kernel: [79596.462674] usb 1-3: Device not responding to setup address.
Apr 27 13:26:10 smurfenaar kernel: [79596.666550] usb 1-3: Device not responding to setup address.
Apr 27 13:26:10 smurfenaar kernel: [79596.874414] usb 1-3: device not accepting address 13, error -71
When it is successful I see:
pr 27 13:22:33 smurfenaar kernel: [79379.772197] usb 1-3: new full-speed USB device number 9 using xhci_hcd
Apr 27 13:22:33 smurfenaar kernel: [79379.899601] usb 1-3: New USB device found, idVendor=0483, idProduct=df11, bcdDe
vice=22.00
Apr 27 13:22:33 smurfenaar kernel: [79379.899605] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 27 13:22:33 smurfenaar kernel: [79379.899607] usb 1-3: Product: STM32 BOOTLOADER
Apr 27 13:22:33 smurfenaar kernel: [79379.899609] usb 1-3: Manufacturer: STMicroelectronics
Apr 27 13:22:33 smurfenaar kernel: [79379.899611] usb 1-3: SerialNumber: 3466365E3135
and I can also see it with the lsusb command:
Bus 001 Device 052: ID 0483:df11 STMicroelectronics STM Device in DFU Mode
