I am trying to use an MPU6050 with my SAMD21-based board (a LightAPRS W-2), but it doesn't work.
The sensor definitely works, as I can get data from another 3.3 Vlogic-level board, and the sensor works with a level shifter with an Arduino Uno.
I do not know what is wrong. My SAMD21 board I2C works fine with other devices, but both the MPU6050 and the MPU9250 don't work. Here is the code I use:
* Example sketch for the MPU9250_WE library
* This sketch shows how to measure pitch and roll angles from the MPU9250.
* I have also included the corrected angle method for comparison.
* For further information visit my blog:
* https://wolles-elektronikkiste.de/mpu9250-9-achsen-sensormodul-teil-1  (German)
* https://wolles-elektronikkiste.de/en/mpu9250-9-axis-sensor-module-part-1  (English)
#include <MPU9250_WE.h> #include <Wire.h> #define MPU9250_ADDR 0x68
/* There are several ways to create your MPU9250 object:
  • MPU9250_WE myMPU9250 = MPU9250_WE() -> uses Wire / I2C Address = 0x68
  • MPU9250_WE myMPU9250 = MPU9250_WE(MPU9250_ADDR) -> uses Wire / MPU9250_ADDR
  • MPU9250_WE myMPU9250 = MPU9250_WE(&wire2) -> uses the TwoWire object wire2 / MPU9250_ADDR
  • MPU9250_WE myMPU9250 = MPU9250_WE(&wire2, MPU9250_ADDR) -> all together
  • Successfully tested with two I2C busses on an ESP32
*/ MPU9250_WE myMPU9250 = MPU9250_WE(MPU9250_ADDR);
void setup() { Serial.begin(115200); Wire.begin(); if (!myMPU9250.init()) { Serial.println("MPU9250 does not respond"); } else { Serial.println("MPU9250 is connected"); }
/* The slope of the curve of acceleration vs measured values fits quite well to the theoretical
  • values, e.g. 16384 units/g in the +/- 2g range. But the starting point, if you position the
  • MPU9250 flat, is not necessarily 0g/0g/1g for x/y/z. The autoOffset function measures offset
  • values. It assumes your MPU9250 is positioned flat with its x,y-plane. The more you deviate
  • from this, the less accurate will be your results.
  • The function also measures the offset of the gyroscope data. The gyroscope offset does not
  • depend on the positioning.
  • This function needs to be called at the beginning since it can overwrite your settings!
*/ Serial.println("Position you MPU9250 flat and don't move it - calibrating..."); delay(1000); myMPU9250.autoOffsets(); Serial.println("Done!");
/* This is a more accurate method for calibration. You have to determine the minimum and maximum
  • raw acceleration values of the axes determined in the range +/- 2 g.
  • You call the function as follows: setAccOffsets(xMin,xMax,yMin,yMax,zMin,zMax);
  • Use either autoOffset or setAccOffsets, not both.
*/ //myMPU9250.setAccOffsets(-14240.0, 18220.0, -17280.0, 15590.0, -20930.0, 12080.0);
/* Sample rate divider divides the output rate of the gyroscope and accelerometer.
  • Sample rate = Internal sample rate / (1 + divider)
  • It can only be applied if the corresponding DLPF is enabled and 0<DLPF<7!
  • Divider is a number 0...255
*/ myMPU9250.setSampleRateDivider(5);
/* MPU9250_ACC_RANGE_2G 2 g (default)
  • MPU9250_ACC_RANGE_4G 4 g
  • MPU9250_ACC_RANGE_8G 8 g
  • MPU9250_ACC_RANGE_16G 16 g
*/ myMPU9250.setAccRange(MPU9250_ACC_RANGE_2G);
/* Enable/disable the digital low pass filter for the accelerometer
  • If disabled the bandwidth is 1.13 kHz, delay is 0.75 ms, output rate is 4 kHz
*/ myMPU9250.enableAccDLPF(true);
/* Digital low pass filter (DLPF) for the accelerometer, if enabled
  • MPU9250_DPLF_0, MPU9250_DPLF_2, ...... MPU9250_DPLF_7
  • DLPF Bandwidth [Hz] Delay [ms] Output rate [kHz]
  • 0           460               1.94           1
  • 1           184               5.80           1
  • 2            92               7.80           1
  • 3            41              11.80           1
  • 4            20              19.80           1
  • 5            10              35.70           1
  • 6             5              66.96           1
  • 7           460               1.94           1
*/ myMPU9250.setAccDLPF(MPU9250_DLPF_6);
void loop() { xyzFloat angles = myMPU9250.getAngles();
/* This method provides quite precise values for x/y angles up 60°. */ Serial.print("Angle x = "); Serial.print(angles.x); Serial.print(" | Angle y = "); Serial.print(angles.y); Serial.print(" | Angle z = "); Serial.println(angles.z);
/* Pitch and roll consider all axes for calculation. According to my experience it provides more reliable results at higher angles (>60°) */ float pitch = myMPU9250.getPitch(); float roll = myMPU9250.getRoll();
Serial.print("Pitch = "); Serial.print(pitch); Serial.print(" | Roll = "); Serial.println(roll); Serial.println();
delay(1000); }
ocrdu
  • 1,795
