I have a HM-10 module connected to my Arduino Nano that I want to use to get data from a ELM327 OBDII.
I have been able to successfully connect to the ELM327 via:
AT
AT+RESET
AT+BAUD2
AT+ROLE1
AT+IMME1
AT+DISC?
AT+CON4823350035BB
I sent "ATZ" through my Serial Console and received nothing.
I then tried other baud rates, with no luck.
I suspected it needs to go to a specific characteristic. So I found the names of the services and characteristics via Light Blue application.
But I see long hex values, where the AT+CHAR command from the datasheet gives a much shorter example.
I have been able to connect via an ESP32 using the BLEDevice.h library - ideally I would like to use a smaller microcontroller such as the Nano.
Is this possible with the Nano?
