I'm trying to write motor controller for automated blinds using Raspberry Pi Pico with arduino-pico.
My problem is that I can't seem to get a consistent result from motor encoders.
In my setup function I attach the interrupt:
void motor0Enc1handler() {
  motor0.handleEnc1();
void setup() { attachInterrupt(digitalPinToInterrupt(motor0.getEnc1()), motor0Enc1handler, RISING); }
Motor is a class with the following interrupt processing code:
int Motor::getEnc1() {
  return _enc1;
void Motor::handleEnc1() {
  // debug only
  if (digitalRead(_enc1) != HIGH) {
    _false_triggers++;
if (digitalRead(_enc2) == HIGH) { // debug only if (!_going_down) { _direction_changes++; } _going_down = true;
_pos = _isLeft ? _pos - 1 : _pos + 1;
} else { // debug only if (_going_down) { _direction_changes++; } _going_down = false;
_pos = _isLeft ? _pos + 1 : _pos - 1;
Interrupt is attached to one of the hall effect sensors on the motor. It has 2 sensors set an angle, so the direction of the motor can be determined. For example, when _enc1 is HIGH and _enc2 is low at the same time it means that the motor is moving in one direction, when _enc2 is also high it moves in the opposite direction.
Here is much better explanation of this.
The main point is that the timing is extremely important to properly calculate the number of rotations the motor made.
For example, if handleEnc1 is delayed the motor would have slightly moved already and digitalRead(_enc2) will return incorrect value.
In my interrupt I've set up a few debugging variables:
_false_triggers is incremented when handleEnc1 is triggered, but when trying to read the same pin value it returns unexpected result. For example, handleEnc1 is triggered on RISING, so I would expect the pin value to be HIGH. If it's not high, it means that the interrupt was delayed and the hall effect sensor is not reporting a different value, because the motor shaft has rotated.
_direction_changes is incremented when motor is supposed to be moving in a single direction, so I would expect digitalRead(_enc2) == HIGH to always be true or false depending on the direction. If the motor keeps turning in the same direction it should never be incremented.
My hardware setup is: Raspberry Pi Pico (_enc1 is pin 20, _enc2 is pin 21). Motor is JGA25-370 with encoders.
Interrupts are triggered at about 2 interrupts per millisecond.
What happens is that I get non-zero _direction_changes and _false_triggers during normal operation:
  • start the motor to go in a single direction
  • serial print direction changes and false triggers from time to time
  • write current motor position into a file with LittleFS in flash memory.
In this case I get about 15-20 _direction_changes per 10000 steps and around 10 _false_triggers. When I disable writing of motor position into a flash file it get less _direction_changes (around 10) and _false_triggers drops to zero, which is an improvement and it proves that the code is susceptible to competing interrupts (I imagine writing to file system or serial uses interrupts). However, this is not ideal, since I need to use SPI as well to talk via nRF24l01 and I also need to persist current motor position periodically in case of a power loss. Also, I don't want to have a position drift for my automated blinds, even though it's relatively small, but it will compound over time.
Am I not using interrupts correctly encoders?
Is there a better way to approach this?
I was thinking about attaching interrupts to both _enc1 and enc2 and push events into a queue and then process it in the main code, but I don't think it's going to work. I can only attach interrupts to either FALLING or RISING so I would be able to detect pulses in a single direction, if I attach interrupts to CHANGE it would mean I'd have to read pin value from within interrupt which is prone to the same issue that I'm already experiencing.
I guess my main problem is that I feel like I shouldn't be having this problem. I only have 2 pulses per millisecond, so it's not that many. Interrupt code is not doing much (unless I'm not supposed to do digitalRead in an interrupt). So I feel like there should be a reliable way to maintain motor position even if there is other stuff going on in the application.
The full code is here in case it's helpful.
Leonti
  • 133
