Analog pontentiometer connected to an Arduino. simplest possible setup.
The goal is to send a message over Serial whenever the value changes.
I do not want to spam the Serial connection to much, so the value has to change by at least 20 (sensitivty threshold) before a message Packet is sent.
However, in reality a message Packet is sent even if the value changed only by 1. Why is sensitivity parameter ignored?
edit: After debugging I can see that it enters the first IF-statement in read(). The IF statement evaluates to 0 which is super weird. It shouldn't have entered that IF statement!
MagicPot.h:
#define MAGIC_POT_MAX_RAW_VALUE_10B 1023
#define MAGIC_POT_MAX_RAW_VALUE_12B 4095
#define MAX_RAW_VALUE_DEFAULT (MAGIC_POT_MAX_RAW_VALUE_10B)
class MagicPot
public:
typedef void (*callback_fn)();
MagicPot(uint8_t pin, uint16_t minRead = 0, uint16_t maxRead = MAX_RAW_VALUE_DEFAULT, uint16_t maxRawRead = MAX_RAW_VALUE_DEFAULT): pin(pin), minRead(minRead), maxRead(maxRead), maxRawRead(maxRawRead) {};
void begin();
bool read(uint8_t sensitivity = 5);
uint16_t getValue();
uint16_t getRawValue();
uint8_t pin;
private:
uint16_t minRead;
uint16_t maxRead;
uint16_t maxRawRead;
callback_fn onChangeCallback;
uint16_t value;
uint16_t rawValue;
MagicPot.cpp:
void MagicPot::begin()
this->onChangeCallback = nullptr;
this->value = 0;
this->rawValue = 0;
pinMode(this->pin, INPUT);
this->read(0);
bool MagicPot::read(uint8_t sensitivity)
this->rawValue = analogRead(this->pin);
uint16_t value = map(this->rawValue, 0, this->maxRawRead, this->minRead, this->maxRead);
if (abs(value - this->value) > sensitivity)
this->value = value;
return true;
else if (value < sensitivity && this->value != this->minRead)
this->value = minRead;
return true;
else if (value + sensitivity > maxRead && this->value != this->maxRead)
this->value = this->maxRead;
return true;
return false;
Arduino code:
MagicPot analogPots[] =
MagicPot(A0),
for (MagicPot& x : analogPots) //arr only contains 1 element
x.begin();
for (MagicPot& pot : analogPots) //arr only contains 1 element
if(true == pot.read(20))
CPPacket* analogPotChangedPacket = new CPPacket(HWEvent::Switch, pot.pin, pot.getValue());
SendPacket( &myPacketSerial, analogPotChangedPacket);
delete analogPotChangedPacket;
Actual Output: (read from computer(conn via Serial))
| Type | Error | Target | Value |
| Switch | NONE | 54 | 516 |
| Switch | NONE | 54 | 515 |
| Switch | NONE | 54 | 514 |
| Switch | NONE | 54 | 513 |
Expected Output:
| Switch | NONE | 54 | 496 |
| Switch | NONE | 54 | 456 |
| Switch | NONE | 54 | 436 |
