First of all if I make a wrong sentence this is because my main language isn't english. I have a homework so i am trying to make a radar with Arduino IDE and Processing. I found and wrote the codes from internet but processing does not respond to ultrasonic sensor and i tought maybe it isn't detecting the serial port. Code from Processing:
import processing.serial.*; // imports library for serial communication
import java.awt.event.KeyEvent; // imports library for reading the data from the serial port
import java.io.IOException;
Serial myPort; // defines Object Serial // defubes variables String angle=""; String distance=""; String data=""; String noObject; float pixsDistance; int iAngle, iDistance; int index1=0; int index2=0; PFont orcFont;
size (1600, 900); // *CHANGE THIS TO YOUR SCREEN RESOLUTION* smooth(); myPort = new Serial(this,"COM3", 9600); // starts the serial communication myPort.bufferUntil('.'); // reads the data from the serial port up to the character '.'. So actually it reads this: angle,distance. orcFont = loadFont("Calibri-Bold-48.vlw"); }
void draw() {
fill(98,245,31); textFont(orcFont); // simulating motion blur and slow fade of the moving line noStroke(); fill(0,4); rect(0, 0, width, height-height*0.065);
fill(98,245,31); // green color // calls the functions for drawing the radar drawRadar(); drawLine(); drawObject(); drawText(); }
void serialEvent (Serial myPort) { // starts reading data from the Serial Port // reads the data from the Serial Port up to the character '.' and puts it into the String variable "data". data = myPort.readStringUntil('.'); data = data.substring(0,data.length()-1);
index1 = data.indexOf(","); // find the character ',' and puts it into the variable "index1" angle= data.substring(0, index1); // read the data from position "0" to position of the variable index1 or thats the value of the angle the Arduino Board sent into the Serial Port distance= data.substring(index1+1, data.length()); // read the data from position "index1" to the end of the data pr thats the value of the distance
// converts the String variables into Integer iAngle = parseInt(angle); iDistance = parseInt(distance); }
void drawRadar() { pushMatrix(); translate(width/2,height-height0.074); // moves the starting coordinats to new location noFill(); strokeWeight(2); stroke(98,245,31); // draws the arc lines arc(0,0,(width-width0.0625),(width-width0.0625),PI,TWO_PI); arc(0,0,(width-width0.27),(width-width0.27),PI,TWO_PI); arc(0,0,(width-width0.479),(width-width0.479),PI,TWO_PI); arc(0,0,(width-width0.687),(width-width0.687),PI,TWO_PI); // draws the angle lines line(-width/2,0,width/2,0); line(0,0,(-width/2)cos(radians(30)),(-width/2)sin(radians(30))); line(0,0,(-width/2)cos(radians(60)),(-width/2)sin(radians(60))); line(0,0,(-width/2)cos(radians(90)),(-width/2)sin(radians(90))); line(0,0,(-width/2)cos(radians(120)),(-width/2)sin(radians(120))); line(0,0,(-width/2)cos(radians(150)),(-width/2)sin(radians(150))); line((-width/2)cos(radians(30)),0,width/2,0); popMatrix(); }
void drawObject() { pushMatrix(); translate(width/2,height-height0.074); // moves the starting coordinats to new location strokeWeight(9); stroke(255,10,10); // red color pixsDistance = iDistance((height-height0.1666)0.025); // covers the distance from the sensor from cm to pixels // limiting the range to 40 cms if(iDistance<40){ // draws the object according to the angle and the distance line(pixsDistancecos(radians(iAngle)),-pixsDistancesin(radians(iAngle)),(width-width0.505)cos(radians(iAngle)),-(width-width0.505)sin(radians(iAngle))); } popMatrix(); }
void drawLine() { pushMatrix(); strokeWeight(9); stroke(30,250,60); translate(width/2,height-height0.074); // moves the starting coordinats to new location line(0,0,(height-height0.12)cos(radians(iAngle)),-(height-height0.12)*sin(radians(iAngle))); // draws the line according to the angle popMatrix(); }
void drawText() { // draws the texts on the screen
pushMatrix(); if(iDistance>40) { noObject = "Out of Range"; } else { noObject = "In Range"; } fill(0,0,0); noStroke(); rect(0, height-height*0.0648, width, height); fill(98,245,31); textSize(25);
text("10cm",width-width0.3854,height-height0.0833); text("20cm",width-width0.281,height-height0.0833); text("30cm",width-width0.177,height-height0.0833); text("40cm",width-width0.0729,height-height0.0833); textSize(40); text("Obje: " + noObject, width-width0.875, height-height0.0277); text("Açı: " + iAngle +" °", width-width0.48, height-height0.0277); text("Mesafe: ", width-width0.26, height-height0.0277); if(iDistance<40) { text(" " + iDistance +" cm", width-width0.225, height-height0.0277); } textSize(25); fill(98,245,60); translate((width-width0.4994)+width/2cos(radians(30)),(height-height0.0907)-width/2sin(radians(30))); rotate(-radians(-60)); text("30°",0,0); resetMatrix(); translate((width-width0.503)+width/2cos(radians(60)),(height-height0.0888)-width/2sin(radians(60))); rotate(-radians(-30)); text("60°",0,0); resetMatrix(); translate((width-width0.507)+width/2cos(radians(90)),(height-height0.0833)-width/2sin(radians(90))); rotate(radians(0)); text("90°",0,0); resetMatrix(); translate(width-width0.513+width/2cos(radians(120)),(height-height0.07129)-width/2sin(radians(120))); rotate(radians(-30)); text("120°",0,0); resetMatrix(); translate((width-width0.5104)+width/2cos(radians(150)),(height-height0.0574)-width/2sin(radians(150))); rotate(radians(-60)); text("150°",0,0); popMatrix(); }
Code from Arduino IDE:
#include <Servo.h>   // servo motor kütüphanesi
#define trigPin 4    // ultrasonik sensör trig pini
#define echoPin 3    // ultrasonik sensör echo pini
Servo servoMotor;     // servo motor nesnesi
int angle = 0;        // servo motor açısı
long duration, distance;  // ultrasonik sensör mesafesi
void setup() { Serial.begin(9600); // seri haberleşme hızı servoMotor.attach(9); // servo motor pin numarası }
void loop() { for(angle = 0; angle < 180; angle += 10){ // servo motor açıları servoMotor.write(angle); // servo motoru hareket ettir delay(200); // bekleme süresi distance = getDistance(); // mesafe ölçümü Serial.print(angle); // açıyı yazdır Serial.print(","); Serial.println(distance); // mesafeyi yazdır } }
long getDistance(){ // ultrasonik sensör mesafe ölçümü pinMode(trigPin, OUTPUT); digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); pinMode(echoPin, INPUT); duration = pulseIn(echoPin, HIGH); distance = duration / 58.2; return distance; }
Thank you for the help!
Earas
Your processing code is looking for something that ends in a '.'
Your arduino code is sending angle,distnace[new line]
So either change your processing code to look for '\n' (the new line character) rather than '.' or change your arduino code to add a . to the end:
Serial.print(",");
Serial.print(distance); // mesafeyi yazdır
Serial.print(".");
Andrew
  • 1,060
