I am working on a project where I am using an HC05 connected to an Arduino to connect to an ELM327 Bluetooth scanner. I am using the SoftwareSerial Arduino library to send and read information from and too the HC05 using the following code. However when I use this code to send PID codes to the HC05 to request data such as 010C I am almost always receiving 010CNODATA>.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(9, 10);
void setup() { Serial.begin(9600); mySerial.begin(38400); }
void loop(){ if (mySerial.available()){ Serial.write(mySerial.read()); } if (Serial.available()){ mySerial.write(Serial.read()); }
My wiring for the HC05 is:
  • EN: No connection
  • VCC: Arduino 5v
  • GND: Arduino Ground
  • TXD: Digital Pin 9
  • RXD: Digital Pin 10
  • STATE: No connection
I have verified that I am linked to the ELM327 device as I do receive the NODATA from the device. I have ensured that the Arduino Serial monitor is in the 'both NL and CR' mode as that is the data format that the HC05 and the ELM327 take.
When I attempt to send AT commands to the ELM327 device the I get a response like A?TZ?>. After much testing I have been able to get all of my commands to work but only if I follow the next steps exactly:
  1. Unplug the Arduino and let it power down.
  2. Plug the Arduino back in and open the Serial monitor and send whatever command I want AT or PID such as ATZ or 010C.
  3. Wait until the HC05 connects to the ELM327 device and the first response that I get back will be correct such as a hex number for RPM.
Any following attempts at sending PID codes will return NODATA. I have verified that both of the devices work independently of each other using the Bluetooth Serial Monitor app. I can send endless AT or PID codes to the ELM327 from my phone and I get the appropriate response. I have a feeling that it is an issue with either the end characters or with the way the data is being sent across the Serial line.
I would be happy to provide any additional information needed.
Thank you.
