i need to wake up my ESP every 60 min to read some data and post it to server, all process working fine when i use numbers of minute below 60 (converted in microsecond x 1000000) but when i use 60 min above i get the following message:
src/main.cpp:137:49: warning: integer overflow in expression of type 'int' results in '-694967296' [-Woverflow] esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);// set up next wake up after 30 sec
How can i make my ESP wake up every 60 min or above?
simplify code:
// for awake and sleep
#define uS_TO_S_FACTOR 1000000
#define TIME_TO_SLEEP  60 // minute
void setup(){ esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * 60 * uS_TO_S_FACTOR);// error if time to sleep more than 60 min
Damiano Miazzi
  • 151
Change that line to:
esp_sleep_enable_timer_wakeup((uint64_t) TIME_TO_SLEEP * 60 * uS_TO_S_FACTOR);
That forces the compiler to do 64-bit arithmetic on the constant rather than defaulting to "int" arithmetic.
Nick Gammon
  • 38,901
