this is the sample code where the user enters A to set the number of times the pet needs to be fed. When I click A on the keypad it asks for the user to set the number. However, the keypad still somehow saves the input of A that is initially pressed. I want the system to ask for another input. How would I clear the memory of the keypad? Here is the code attached
/* Hello Wokwi! */
#include <Keypad.h>
#include <LiquidCrystal_I2C.h>
const int ROW_NUM = 4; // four rows
const int COLUMN_NUM = 4; // four columns
char keys[ROW_NUM][COLUMN_NUM] = {
{'1','2','3', 'A'},
{'4','5','6', 'B'},
{'7','8','9', 'C'},
{'*','0','#', 'D'}
int col = 0, row =0;
byte pin_rows[ROW_NUM] = {10,9,8,7}; // connect to the row pinouts of the keypad
byte pin_column[COLUMN_NUM] = {6,5,4,3}; // connect to the column pinouts of the keypad
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
Keypad keypad = Keypad(makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
void setup () {
lcd.init(); // initialize the lcd
lcd.backlight();
lcd.setCursor(col,row); // move cursor to (cursorColumn, 0)
lcd.print("HI OWNER");
delay(3000);
int h1,h2,hf1,min1,min2,minf1;
int numfed,setnofeed=0;
char key = keypad.getKey();
if(!key){
displaytime();
switch(key){
case 'A':
lcd.print("SET NO. OF");
lcd.setCursor(col,1);
lcd.print("FEEDING TIMES");
delay(3000);
lcd.clear();
lcd.print("MAX 5 MIN 2");
col=0;
if (col==0&&setnofeed==0){
numfed=key-48;
lcd.print(numfed);
delay(1000);
col=1;
else if(col==1){
lcd.clear();
lcd.print("NO. OF FEEDING");
lcd.print("SET");
delay(2000);
setnofeed=1;
break;
void displaytime(){
lcd.setCursor(0,0); // move cursor to (cursorColumn, 0)
lcd.print("Time now:");
