I am using the following device: https://www.aliexpress.com/item/1005003152097545.html?spm=a2g0o.order_list.order_list_main.119.222218028PapM6
I am trying to make an IoT sound-measurer which will send an SMS, once a sound above a certain threshold has been registered for a certain amount of time. Furthermore, it should send a "pulse" SMS every Nth hour, to ensure, that the module is still alive.
To achieve the SMS-part of this project I am using the TinyGSM module. It worked for a long time, and then suddenly it wouldn't work anymore. The only related event I can think of that happened before this, is that I tried to use the modem on the ESP-IDF, and I tried to use the GPS capabilities of the modem, once again on the ESP-IDF.
I believe this might have had something to do with the settings I had sat on the ESP-IDF, which are defined through the following AT-commands: "AT+CFUN=0\r", "AT+CPIN="1234"\r", "AT+COPS=0,0,"Telenor DK Telenor DK",7\r", "AT+CMGF=0\r".
But after running "AT+CRESET" and "AT+CPOF" and rerunning the Arduino script, I am still stuck with the original error.
The error occurs, when I try to run the sendText method, and the message (With my phone number redacted) is:
AT+CMGF=1
AT+CMGF=1
ERROR AT+CSCS="GSM" AT+CSCS="GSM"
ERROR AT+CMGS="+REDACTED" AT+CMGS="+REDACTED"
ERROR
The full Arduino code (Where I've once again written REDACTED instead of my actual IRL phone number):
//SIMKORT indstillinger
// Pincode for simkortet #define GSM_PIN ""1234""
// GRPRS credentials for simkortet const char apn[] = "Telenor Internet"; //SET TO YOUR APN const char gprsUser[] = ""; const char gprsPass[] = "";
// Nummer til SMS samt besked #define SMS_TARGET_NOISY "+REDACTED" #define SMS_TARGET_PULSE "+REDACTED" #define SMS_MESSAGE_NOISY "B" #define SMS_MESSAGE_PULSE "L"
//Netværks indstillinger fra Debugging 1 koden #define NETWORK_MODE 2 #define PREFFERED_NETWORK_MODE 2
//Modem indstillinger #define TINY_GSM_MODEM_SIM7600 //Om du bruger SIM7000 eller SIM7600 (TTGO'en er 7600) #define TINY_GSM_RX_BUFFER 1024 // Set RX buffer to 1Kb #define SerialAT Serial1
//Libraries #define DUMP_AT_COMMANDS //Bruges til debugging
#include <TinyGsmClient.h> #include <SPI.h> #include <SD.h> #include <Ticker.h>
#ifdef DUMP_AT_COMMANDS // if enabled it requires the streamDebugger lib #include <StreamDebugger.h> StreamDebugger debugger(SerialAT, Serial); TinyGsm modem(debugger); #else TinyGsm modem(SerialAT); #endif
//ESP32-Modem Forbindelser Indstillinger #define uS_TO_S_FACTOR 1000000ULL // Conversion factor for micro seconds to seconds
#define UART_BAUD 115200 #define PIN_DTR 25 #define PIN_TX 27 #define PIN_RX 26 #define PWR_PIN 4
//SD Kort forbindelser #define SD_MISO 2 #define SD_MOSI 15 #define SD_SCLK 14 #define SD_CS 13 #define LED_PIN 12
int counter, lastIndex, numberOfPieces = 24; String pieces[24], input;
//Indstillinger for dBAMåleren #define VREF 3.3 //Voltagen som din MCU bruger, Arduino = 5 #define soundSensorPin 25 //Den pin på MCU'en, der er forbundet til outputtet på dBA måleren #define analogMaxRange 4096 //Analog max range for din MCU, esp32: 4096, Arduino: 1023
//Funktionelle indstillinger #define dBAMax 3.0 //Hvornår der skal sendes en SMS #define errorMeasurement 0.0 //Fejlmarginen #define waitBeforeSendingtext (101000) //Målt i millisekunder, tid før vi sender noisySMS #define waitBeforeGoingIdle (1001000) //Hvor lang tid dBAMeasurement må være under vores dBAMax, før vi går tilbage til idle stadiet #define waitIntervalBetweenPulseText (1000*1000) //Antal millisekunder i mellem, at vi sender en pulse SMS
//Variable vedrørende FSMD'en - MÅ IKKE ÆNDRES //States: //Idle 0, dBA above Max 1, dBA momentarily below max 2, send noisy text 3, send pulse text 4 int state = 0; //Initialiserer stadiet ved 0 float dbAMeasurement; unsigned long timeSinceLastIdle; //Bruges til at triggere loudSMS unsigned long timeSinceLastPulse = 0; //Bruges til at pulseSMS unsigned long timeSincedBAMax; //Tid der er gået siden, vi optog vores første dBAMax i denne omgang
//Funktioner
void sendText(String SMSTarget,String message,TinyGsm modem){ modem.sendSMS(SMSTarget, message); }
float getdBAMeasurement(){ float dbAMeasurement = ((analogRead(soundSensorPin) / 4096.0 * VREF)*50.0); //Slipper for at bruge clock cycluser på at definere variable delay(125); //Sampling cyclus delay for stabilitet return dbAMeasurement; }
bool isAbovedBAThreshold(){ float dbAMeasurement = getdBAMeasurement(); if(dbAMeasurement>(dBAMax - errorMeasurement)){ return true; }else{ return false; } }
void setup() { Serial.begin(115200);
//Opstart af Modem // Set LED OFF pinMode(LED_PIN, OUTPUT); digitalWrite(LED_PIN, HIGH);
pinMode(PWR_PIN, OUTPUT); digitalWrite(PWR_PIN, HIGH); delay(300); digitalWrite(PWR_PIN, LOW);
//Tjekker for SD kort SPI.begin(SD_SCLK, SD_MISO, SD_MOSI, SD_CS); if (!SD.begin(SD_CS)) { Serial.println("SDCard MOUNT FAIL"); } else { uint32_t cardSize = SD.cardSize() / (1024 * 1024); String str = "SDCard Size: " + String(cardSize) + "MB"; Serial.println(str); }
Serial.println("\nWait...");
delay(1000);
SerialAT.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
// Restart takes quite some time // To skip it, call init() instead of restart() Serial.println("Initializing modem..."); if (!modem.restart()) { Serial.println("Failed to restart modem, attempting to continue without restarting"); }
// Unlock your SIM card with a PIN if needed if ( GSM_PIN && modem.getSimStatus() != 3 ) { modem.simUnlock(GSM_PIN); } modem.sendAT("+CFUN=0 "); if (modem.waitResponse(10000L) != 1) { DBG(" +CFUN=0 false "); } delay(200);
/* 2 Automatic 13 GSM only 38 LTE only 51 GSM and LTE only
String res; // CHANGE NETWORK MODE, IF NEEDED res = modem.setNetworkMode(NETWORK_MODE); if (res != "1") { DBG("setNetworkMode false "); return ; } delay(200);
/* 1 CAT-M 2 NB-Iot 3 CAT-M and NB-IoT
// CHANGE PREFERRED MODE, IF NEEDED res = modem.setNetworkMode(PREFFERED_NETWORK_MODE); if (res != "1") { DBG("setPreferredMode false "); return ; } delay(200);
/*AT+CBANDCFG=<mode>,<band>[,<band>…]
  • <mode> "CAT-M" "NB-IOT"
  • <band> The value of <band> must is in the band list of getting from AT+CBANDCFG=?
  • For example, my SIM card carrier "NB-iot" supports B8. I will configure +CBANDCFG= "Nb-iot ",8
/ / modem.sendAT("+CBANDCFG=&quot;NB-IOT&quot;,8 ");*/
/* if (modem.waitResponse(10000L) != 1) { DBG(" +CBANDCFG=&quot;NB-IOT&quot; "); }*/ delay(200);
modem.sendAT("+CFUN=1 "); if (modem.waitResponse(10000L) != 1) { DBG(" +CFUN=1 false "); } delay(200);
SerialAT.println("AT+CGDCONT?"); delay(500); if (SerialAT.available()) { input = SerialAT.readString(); for (int i = 0; i < input.length(); i++) { if (input.substring(i, i + 1) == "\n") { pieces[counter] = input.substring(lastIndex, i); lastIndex = i + 1; counter++; } if (i == input.length() - 1) { pieces[counter] = input.substring(lastIndex, i); } } // Reset for reuse input = ""; counter = 0; lastIndex = 0;
  for ( int y = 0; y &lt; numberOfPieces; y++) {
    for ( int x = 0; x &lt; pieces[y].length(); x++) {
      char c = pieces[y][x];  //gets one byte from buffer
      if (c == ',') {
        if (input.indexOf(&quot;: &quot;) &gt;= 0) {
          String data = input.substring((input.indexOf(&quot;: &quot;) + 1));
          if ( data.toInt() &gt; 0 &amp;&amp; data.toInt() &lt; 25) {
            modem.sendAT(&quot;+CGDCONT=&quot; + String(data.toInt()) + &quot;,\&quot;IP\&quot;,\&quot;&quot; + String(apn) + &quot;\&quot;,\&quot;0.0.0.0\&quot;,0,0,0,0&quot;);
          input = &quot;&quot;;
          break;
      // Reset for reuse
     } else {
      input += c;
} else { Serial.println("Failed to get PDP!"); }
Serial.println("\n\n\nWaiting for network..."); if (!modem.waitForNetwork()) { delay(10000); return; }
if (modem.isNetworkConnected()) { Serial.println("Network connected"); }
switch(state){ case 0: // Idle: Venter på at dbAMeasurement går over dbAMax - Error Serial.println("Back in state 0"); dbAMeasurement = getdBAMeasurement(); timeSinceLastIdle = millis(); //Millisekunder siden start Serial.println(dbAMeasurement); Serial.println(timeSinceLastIdle); Serial.println(timeSinceLastPulse);
  if((timeSinceLastIdle - timeSinceLastPulse) &gt; waitIntervalBetweenPulseText){ //Vi vil hellere sende pulse SMS'en, før vi advarer
    state = 4;
  if ((dbAMeasurement&gt;(dBAMax - errorMeasurement))&amp;(state != 4)){ //If we go above the allowed dBAMeasurement, we start counting until we send noisySMS
    state = 1;
  break;
case 1:  // We're counting up to sending the loudSMS
  Serial.println(&quot;Back in state 1&quot;);
  timeSincedBAMax = millis() - timeSinceLastIdle;
  Serial.println(timeSincedBAMax);
  if(timeSincedBAMax&gt;waitBeforeSendingtext){
    state = 3; //SendnoisySMS
  if(dbAMeasurement&lt;(dBAMax - errorMeasurement)){
    state = 2; //Momentært under dBAMax
  break;
case 2:  // Hvis vi momentært går under dBAMax
  Serial.println(&quot;Back in state 2&quot;);
  if((millis() - timeSincedBAMax)&gt; waitBeforeGoingIdle){ //Når der er gået lang nok tid, hvor vi ikke måler en høj nok lyd, så genstarter vi timeren for at sende noisySMS
    state = 0;
  if(dbAMeasurement&gt;(dBAMax - errorMeasurement)){ //Vi går igen over vores threshold og går tilbage til tælle op til at sende noisySMS uden at genstarte timeren
    state = 1;
  break;
case 3:  // Send noisySMS
  sendText(SMS_TARGET_NOISY,SMS_MESSAGE_NOISY,modem);
  Serial.println(&quot;Back in state 3&quot;);
  state = 0;
  break;
case 4:
  Serial.println(&quot;Back in state 4&quot;);
  timeSinceLastPulse = millis();
  sendText(SMS_TARGET_PULSE,SMS_MESSAGE_PULSE,modem);
  state = 0; //Go back to idle
  break;
The odd thing here however, is that if I manually send the AT commands over UART using the ESP-IDF, I can make it send text messages without a hick.
BurgerMan
