I am trying to have a header file to handle all my pin definitions and pinmodes.
This is the header:
#ifndef __HEADER_TESTER__
#define __HEADER_TESTER__
#include <SoftwareSerial.h> const byte rxPin = 2; const byte txPin = 3; SoftwareSerial mySerial(rxPin, txPin);
pinMode(LED_BUILTIN, OUTPUT);
#endif
However, when I compile this, I get an error on the pinMode(LED_BUILTIN, OUTPUT); line:
expected constructor, destructor, or type conversion before '(' token
user1584421
  • 1,425
  • 26
  • 36
The pinMode() statement is executable code and can not be executed outside of a function - setup(), loop(), or some other function defined by you. One could imagine defining a function in your header (.h) file to set your pin modes but defining code in a header will cause a different kind of problem (multiple definitions) if you ever add another code module, a .cpp file, for instance, that also includes this same .h file.
Pin modes are usually set in the setup() function, once per execution of the sketch. There really isn't much value to having them in the .h file. If it is for documentation purposes, you could #define in the .h file, a symbol that expands to all of the pinMode() calls you need, then write that symbol at the appropriate place in your setup() function where it's expansion will be syntactically correct. This would accomplish the documentation, but at the cost of a reader of your code having to search for the definition of that symbol to find out what code is being executed there. That's pretty roundabout for what seems like little to no gain.
JRobert
  • 15,407
