I’ve got a question about this code I’ve attached please- would it be correct to read it like this:
After defining the variable temperature and humidity and assigning measurement_timestamp to millis(), an if loop first checks if millis - measurement_timestamp < 3000 unsigned long (which doesn’t make sense to me) and then if a reading is read, it = true?
Is this correct please?
Code:
static bool measure_environment( float *temperature, float *humidity )
static unsigned long measurement_timestamp = millis( );
/* Measure once every four seconds. */
if( millis( ) - measurement_timestamp > 3000ul )
if( dht_sensor.measure( temperature, humidity ) == true )
return( true );
return( false );
