I have a sim800l module connected to the Rpi pico hardware UART
SIM800 RPi Pico
5v *External 2A 5v supply*
GND GND
VDD 3v3
TXD GP1
RXD GP0
void setup()
Serial.begin(115200);
while (!Serial)
Serial1.begin(9600);
Serial.print("Initializing");
delay(1000);
Serial.print(".");
delay(1000);
Serial.print(".");
delay(1000);
Serial.println(".");
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
Serial1.println("AT"); //Once the handshake test is successful, it will back to OK
updateSerial();
delay(3000);
Serial1.println("ATI"); //Returns the module name and revision.
updateSerial();
delay(3000);
Serial1.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged
updateSerial();
delay(3000);
Serial1.println("AT+COPS?"); //Checks which network you are connected to
updateSerial();
delay(3000);
Serial1.println("AT+COPS=?"); //Returns the list of operators present in the network.
updateSerial();
delay(3000);
void loop()
updateSerial();
void updateSerial()
delay(200);
while (Serial.available())
Serial1.write(Serial.read());//Forward what Serial received to Software Serial Port
while (Serial1.available())
Serial.write(Serial1.read());//Forward what Software Serial received to Serial Port
terminal response
AT
OK
ATI
SIM800 R14.18
OK
AT+CCID
XXXXXXXXXXXXXXXXXXXX
AT+COPS?
+COPS: 0,0,"Vodaa TelAT+COPS=?
+COPS: (2,"Vodaa Telecom","Ver
From what i know so far the SIM800L always ends its response with an "OK" but there are some commands that are cut short and not end with OK. such as AT+CDID and AT+COPS. I do not know if the problem is with the pico or with sim800l. The sim800l seems to be working fine so i suspect its with the pico but if so, it might be a problem with the internal libraries which is beyond me. To supoort that theory the number of characters that is being cut is about 20 characters, so it might be a setting i have to adjust
